Page 166 of 307 FirstFirst ... 66116156162163164165166167168169170176216266 ... LastLast
Results 1,651 to 1,660 of 3070
    Sep 2006
    #1651
    Will you be using the flac capabilities?
    Aug 2014
    #1652
    Hi mga sir.. Tanong ko lang. About " Trapick Audio" ok ba sir yung shop na to? For loud and clear set up
    Aug 2010
    #1653
    Quote Originally Posted by simonzaide View Post
    Friends
    Torn between these 2 head units
    Pioneer avh 8750 and Pioneer avh 5750
    Theres an 11k difference between the 2
    Given i would have an external processor and wont use its tuning capabilities is the extra 11k justifiable to go for the 8750 or should i just stick to the 5750
    Stick with the 5750 as you have an external processor.
    Friends
    Feb 2011
    #1654
    Friends
    Boss Simon, ano pala yung sinasabi nilang network mode feature that the 5750 has. What does it do?
    Jun 2014
    #1655
    Di rin ako familiar with the network mode
    Jun 2014
    #1656
    Regarding deadening is it important to deaden the rear doors or the drunk considering sq yung set up
    Feb 2011
    #1657
    For me, unless you hear your trunk resonating, then by all means do deadening. For rear doors, if your rear speakers are disconnected, i find more value in deadening the floor and ceiling since those can be the first point of reflection.
    Natanong ko na din boss Simon kay Jonz what network mode is on the 5750, parang some sort of full-active capability the HU has that the 8750(not sure of the model) does not have.
    Jun 2014
    #1658
    Thanks boss so medyo wala rin pala masyadong value for money mag padeaden ng rear door and trunk
    Aug 2010
    #1659
    #FYI
    I just have deadening on the front doors.
    #FYI
    #1660
    Good day
    Considering to upgrade to a pioneer headunit avh-x8750bt from stock unit of montero sport gtv. Question is can I still make use of the rear camera and re-activate tpms? Does winterpine have a toms unit so I can still use the tpms sensors attached to the wheels? TIA
audio set-up for beginners [continued]
