Results 1,661 to 1,670 of 3070
May 7th, 2015 06:32 PM #1661
Ano possible reason ng biglang namamatay na amplifier/nawawala yung bass pag nagpapatugtog ako on high volume? TIA
- Mar 2009
- 376
May 7th, 2015 08:06 PM #1662
May 7th, 2015 10:25 PM #1663
- Mar 2009
- 376
May 8th, 2015 03:13 AM #1664Naranasan ko kasi dati yung subwoofer ko 2 ohms (nakasukat yan sa label nung sub), hindi pala kaya nung amplifier kaya tuwing may malakas na bass, ayun trip off lagi, napo-"protect". Yung amp ko nun nakalagay sa label recommended for 4 ohms.
Pwede mong subukan bawasan ng konti yung level dun sa amplifier mismo. Yung balanse lang yung lakas ng subwoofer sa ibang speakers mo. Tapos check mo yung ampli kung may bass boost na switch, off mo rin muna yun. Ano pa ba adjustments sa ampli mo?
- May 2015
- 37
May 9th, 2015 05:07 PM #1665Mga sir patulong lng po sana ako. Ok lng po kaya ganitong setup?
TS-WX303 (Archived) - Pioneer UK and GM-A3602 - <b>NEW!</b> - 2-Channel Bridgeable Amplifier | Pioneer Electronics USA
Already have the subs nasira po kasi un last ampli and planning a straight Pioneer setup. TIA!
- Jun 2014
- 64
May 10th, 2015 11:47 PM #1666I would like to thank this thread for all the wonderful suggestions and help you guys gave
Boss sientobente and jhnkvn thank you very much for your valuable inputs and for constantly answering my inquiries
By the way shameless plug to toyota altis 11th gen owners theres a new pioneer avh xl5750bt its 200mm wider than normal avh units so no more need for the spacers mas stock looking downside is its pricier by a few thousands than the regular 5750.
May 19th, 2015 12:05 PM #1667
mga sirs
ano feedback natin sa Kinetic HU?
Maganda ba gamitin ung touch screen? Ok ba ung screen and hindi pixelated?
Kaya mag play ng Mkv?
May 27th, 2015 10:30 AM #1668
Hi, I'm a complete noob when it comes to aftermarket audio systems. However, I need to use up 10k worth of casa accessories for the car I'm buying, and I took interest in the AVT ISW-8500, an 8.5" powered under-seat sub.
I read about these small active subs and while they don't make a big difference, it's still noticeable vs a completely stock setup - it's free anyway so why not. However, my SA called me today and said that the Altis HU has no sub out, and they will have to splice existing wires to install the subwoofer.
From my understanding, that's like using a 2-channel stereo setup and trying to make it sound like a 2.1. However, since there isn't a dedicated sub out, the sound data that will be sent out to the sub will be the same as what's sent out to the speakers - effectively making it a 7th speaker instead of a dedicated sub. So I won't really be getting the bass boost I was looking for.
Please correct me if I'm wrong, as I currently have the installation of the sub on hold until I have a better understanding of the implications of the setup. Thanks!
- Jul 2009
- 3,604
May 27th, 2015 11:23 AM #1669Can't upgrade the HU nalang first? Touchscreen with phone mirroring sana hehehe.
May 27th, 2015 01:24 PM #1670
First of all dapat pinasa nang SA mo yun fon sa tao na nag iinstall niyan, hehe!
It's like this, your HU has a front and rear stereo signal output. If you will install the active subs, you simply use the REAR signal output of the HU, with the expense of not using the rear speakers. If you do it this way you can now somehow make use of the fader of the HU, to control the volume of the active subs. If you still want to make use of your Rear speakers, simply tap the wire to the front speakers. Usually naman ang mga oem speakers are 4ohms, wire them in parallel and you have now have a 2ohm impedance on the speakers which the oem HU can handle. But IMO, If I was in your situation, I would disregard the use of the rear speakers. You have better sound stage if all the sound of the speakers are coming from the front.
Tesla Philippines
