Results 1,101 to 1,110 of 3070
- Dec 2009
- 16
July 7th, 2014 01:04 AM #1101Good evening. Plano ko sana upgrade ng sound system. Yung 2din headunit ko kasi nag loloko na touch screen. Plano ko sana isabay pag nagpalit ako headunit. Medyo marami na rin ako nabasa sa thread kaso di ko alam kung saan ako mag start kung ako mag sesetup. Pahingi naman tips saan ako mag start, Ano ba dapat bibilhin ko, and saan ko ba ipapasetup.
Sa ngayon, stock speakers lang ng altis 1.8g 2002 model gamit ko. Hindi naman ako nabibitin sa tunog niya. Or siguro wala naman ako nacocompare. Yung sa office ko nag nakasetup na kanya pero d ako nagagandahan sa tunog. Parang d balanse yung bass nya (sobrang dagundong) and masakit naman yung kalansing. D ko naririnig yung ibang instrument. Mas na appreciate ko pa yung stock speaker ko.
Gusto ko sana magpalit na matutuwa naman ako sa kalalabasan. Ano ba marerecommend nyo? Yung sakto lang sa budget. Yung 20k ba kaya na?
Posted via Tsikot Mobile App
July 7th, 2014 07:04 AM #1102
since happy ka naman sa speakers mo and magpapalit ng HU, buy a quality HU first then have your doors deadened, it'll make your speakers (or any speakers for that matter) sound way better. Then, ipon na lang in case you want to push through your plans of upgrading your system. With that very tight budget, mahirap kasi yung quality HU + amp + speakers, especially kung may particular sound signature kang hinahanap.
Also, better kung makaka-audition ka ng quality install talaga, try to ask jhnkvn if he could spare some time para ma-audi mo system nya.Last edited by ezem; July 7th, 2014 at 07:07 AM. Reason: dagdag bawas
July 7th, 2014 07:14 AM #1103
jhnkvn, patulong uli
confused on which speakers to consider...
very brief...
in your opinion, which one would sound best given the same condition (gears & install) for SQ
Focal Access 3-way (semi-active)
or
Audison Voce 2-way (full active)
or
Hertz Mille 2-way (full active)
TIALast edited by ezem; July 7th, 2014 at 07:17 AM. Reason: dagdag bawas
- Dec 2009
- 16
July 7th, 2014 12:31 PM #1104Thanks Ezem. Paano pag uunti untiin ko sya. Saan kaya ako mag start? Head unit, then ampli, last yung speakers? Kung sa HU ano ba maganda na nsa 10k? Ganun din sa ampli and speakers. Naka line up na sana yung bibilhin. Yung pang budgeted na maganda. Yung tipong d sya mura, hindi rin sobrang mahal. Pero nsa range ng sulit ü
July 7th, 2014 01:30 PM #1105
you wanted a 2-din HU right? o single din?
if 2-din, stretch your budget a little kasi ang avh-x2650bt is around 14k
if single din, look for a 2nd hand 9887 or if bnew, deh-x9650bt is around 8k
go for a decent HU first...then kung pwede sana pagsabayin yung speakers & amp...
but if not possible, go with speakers first, the new Focal access is great (7k), and also Auditor RIP (5k)...morel tempo is also there but that would be more than 10k already
for amp, your choices for bang for the buck would be Soundmagus VS160.4, Cadence 175.4, Gladen M-line 75.4, & Firland XA480, I think all of these would be more or less 8k-10k range...go with 4ch as jhnkvn would also advise you...if ever you plan to have a sub in the future.
- Dec 2009
- 16
July 7th, 2014 01:34 PM #1106Thanks Ezem, research ko muna yung mga sinabi mo.
Saang shop kayo nag papagawa? May nabasa ako dito na kay Jay sila nagpapagawa. Saan kaya yun? May ma rerecommend ba kayo. Malapit ako sa evangelista pero pwede rin naman ako pumunta ng banawe.
July 7th, 2014 05:34 PM #1108
A 3-way will entail more costs than your 2-way. Wiring is one.. installation and fabrication is the other. But as long as you tune it right, even a basic 3-way will outperform a more expensive 2-way. So the Focal Access 3-way gets my vote.
The logic is very much like a turbo car versus a N/A engine. Given a certain distance, the turbo car will be better (faster) and it'll also be more failure-prone (BOV, turbocharger, etc.). You also need to tune the ECU well so you can take advantage of the added power. But when it all boils down to it, if you don't tune it well.. your 3-way will suck. And tuning a 2-way is significantly easier than a 3-way setup.
- May 2006
- 33
July 7th, 2014 09:56 PM #1109How about mbquart dsc4125 amp sir? Nagpaquote kasi ko kay sir jeff tan, php8500 daw. Magandang klase din ba yan o mas ok pa din yung sound magus? Naghahanap kasi ako ng shop na nandun na lahat ng kailangan ko para mabigyan ako ng discount or free installation. Thanks.
July 8th, 2014 02:18 AM #1110
