Results 1,001 to 1,010 of 3070
- Apr 2011
- 8
- Nov 2009
- 38
April 24th, 2014 04:13 PM #1002
- Mar 2014
- 63
April 24th, 2014 05:26 PM #1003Sa mga gurus medyo naguluhan ako sa wiring. Ito system ko kicker cvr8 and punch 301s. Paano ba wiring gagawin ko sa dvc na cvr8? Puede kaya iparallel ko tapos bridge sa amp or 1st voice coil connect sa left ch ng amp then 2nd vc connect to right channel ng amp to make it stereo or mag series ako then bridge sa amp. Alin kaya ang maganda dito? Tia
Posted via Tsikot Mobile App
- Nov 2009
- 38
April 24th, 2014 06:10 PM #1004Not a guru here pero this might help.
Since ur amp is rate as 75 x 2 * 4ohms or 300 watts x 1 *4ohms,
best to wire your dvc sub to meet a 4ohm load (assuming its a dual 2ohm) by wiring it in series
you can do so by getting a wire to connect the + and - and then hooking the remaining + and - negative terminals to your amp's corresponding terminal in bridge mode.
Dual Voice Coil Wiring Options | KICKER
- Mar 2014
- 63
April 24th, 2014 08:05 PM #1005
April 25th, 2014 03:10 AM #1006
April 28th, 2014 10:31 AM #1007
Just like to get advice if the performance of the JBL MS-8 will be at par with the Alpine PXA-H800. Will hook it up to a montero head unit with amps for the speakers and sub.
Also, are there ships where you can buy just speaker crossovers. The left front Jbl speaker on my other car has gave out.
TIA
April 28th, 2014 04:00 PM #1008
Although if you look at them as a processor-only, nasa same category sila. However... they are marketed differently and this means na apples to oranges comparison mo dito.
The MS8's promise is a 5-minute auto-tune that's very intelligent while the H800 has all the features you need but you need to know how to tune it.
What's better depends on how good are you in tuning.
- Mar 2014
- 63
April 30th, 2014 02:19 AM #1009Hello ulit mga bossing. May problem ako. Bigla na lang namamatay headunit kasama amp. Mahina o malakas sounds namamatay pa rin. Natry ko na ioff yung power ng amp. Pag headunit alone lang, di naman namamatay. Ano kaya ang may sira? Amp or yung speaker? Pag na on ko ulit ok naman lahat tapos bigla uli nag shut off. Nagrereset ung headunit. Ito system ko
Pioneer Deh1450ub
Stock front speakers
Rf punch 301s
Kicker cvr8 dual 4 ohms
Tia
April 30th, 2014 02:50 AM #1010
Probably a short circuit issue on your power amp. Try checking its fuse if still intact.
Tesla Philippines
