Page 236 of 307 FirstFirst ... 136186226232233234235236237238239240246286 ... LastLast
Results 2,351 to 2,360 of 3070
    Apr 2017
    #2351
    Thanks mga sir nakapag pa install na ako last sat. (Mickeys)
    HU: Alpine CDE148bt
    Front: DLS RZ6.2
    Amp: Sonus Enigma 4.100
    Sub: Pioneer premier 8" shallow
    Wirings/Deadeners: Audiomax Pro/Silent Coat
    Anyway may extra deadners pala na binigay sakin, as in kasing laki lang ng box ng sub ko (downfire sa ilalim ng driver seat)
    Okay ba na ilagay yung deadeners sa ilalim ng sub or no?
    Feb 2011
    #2352
    Quote Originally Posted by Lzarellano View Post
    HU: Alpine CDE148bt
    Front: DLS RZ6.2
    If you hear resonance or things shaking under your sub then deadening will help, if not, no need. Congrats on that sweet setup by the way!
    Apr 2017
    #2353
    Quote Originally Posted by sientobente View Post
    Ok sir thanks!! :D
    Feb 2015
    #2354
    Ok lang ba na unahin ko dsp kesa sa subwoofer? Also malaki ba ang difference ng 70w per channel na amp compared sa 100w per channel? Assuming na galing sa same line ng amps at normal listening volume lang naman?
    Apr 2017
    #2355
    Quote Originally Posted by reptar View Post
    Sub muna siguro sir para mas buo na agad tunog? Kahit mura lang naman na sub oks na hehe. Kung normal listening volume ok na ang 70w.
    Feb 2011
    #2356
    On normal listening volumes, you may not hear the difference unless your speakers have low sensitivity. I also agree to go with subs first.
    Feb 2015
    #2357
    Thanks. Akala ko kasi you need more power kapag ng full active ka compared kapag may passive x over?
    For a budget of 10k anong ok na sq sub?
    Sent from my iPhone using Tapatalk Pro[/QUOTE]
    Apr 2017
    #2358
    [/QUOTE]
    Not sure dun sa power ng active vs passive.
    Yung binilhan ko ng amp dati, Nag champ sya sa emma ng gamit nya ay Morel Primo sub lang. Nasa 9.2k ata yung 10inch nun. Ang alam ko rin maraming gumagamit nyan.
    Feb 2011
    #2359
    Not necessary naman, unless again your drivers have low sensitivity. For a sub around that budget, a lot fits under 10k. I have both the Focal 25a4 and Hertz ES250.5 and they are around that price. The 10" Sub ng Helix also fits your budget.
    Feb 2015
    #2360
    Thanks for the suggestions. Ano naman kaya ok na mono amp? Budget is around 10k din siguro. Im trying to keep the total cost below 30k kasama na installation. Also hoping na medyo magtagal sana setup na to sakin before I feel the itch again hehe.. btw I already have a focal 165f and an incoming zapco amp gift from my sis. The reason that I was thinking of getting a dsp first is because di ko mapapalitan ang headunit ng Mazda 2 skyactiv
audio set-up for beginners [continued]
