Results 2,381 to 2,390 of 3070
- Apr 2017
- 45
May 21st, 2017 01:30 PM #2381Okay talaga sa mickeys. 3 kami taga LosBanos, Laguna ng mga kaibigan ko, dinadayo talaga namin mickeys. Yung isa Bewith setup, yung isa DLS setup.
May 26th, 2017 10:11 AM #2382
Question sa mga audio gurus here. My car is a suzuki jimny. I want to upgrade the stock speakers. 4" speakers and front lang meron. I plan to replace the front speakers and add rear speakers (meron ng wire provision). I have inquired in several audio shops. Laging recommended sa akin is to replace the front speakers to coax speakers daw. Do i really need the tweeters? And gusto nung isang audio shop butasan door cards and doon lagay speakers. Stock location is at the bottom of the dashboard.
I just want a little better sound that stock.
May 26th, 2017 10:38 AM #2383
By doing a "feasibility study" on a Jimny before, coax lang pwede. If you want seps medyo kailangan i-sacrifice yung door cards which you've mentioned. If you only want a better than stock sound, pwede na coax upgrade lang. Then kung bitin lagyan nalang ng amplifier below the passenger seat.
If i were in your shoes, i'm more than willing to sacrifice my door cards para malagyan ng seps.Then kapag bebenta na yung kotse bili nalang ulit ng panibagong door card.
May 26th, 2017 02:38 PM #2384
got it sir. pag nag coax speakers na ako, does it mean I need to add rear speakers pa? or no need na?
as for the amplifier, is it needed if nag upgrade ako to coax na 4 inches parin? most likely hindi ko na bubutasan door cards since this will just be a very basic upgrade lang
sorry. totally noob when it comes to audio set up
May 26th, 2017 03:17 PM #2385
It really depends sayo if you'll want to add rear speakers. Please check if same size lang yung coax sa front and provision sa rear. Kung sakto, lipat nalang sa rear yung stock front speakers para hindi sayang and it will act as a "filler" sa cabin ng sound.
I think that you do not need the amp if that would be the case. Kakayanin naman ng head unit.
BTW, are you gonna use the stock head unit or papalitan mo din along the way or napalitan mo na?
May 26th, 2017 04:40 PM #2386
Naka pioneer na headunit na sir. Sayang nga yung Alpine 117E when i sold my fieldmaster. Hindi ko na naibaklas.
Same size front and rear. Pwede ko nga lipat nalang yung old stock speakers sa rear, then add front coax.
Thanks for the advice
- Apr 2017
- 45
May 27th, 2017 11:33 PM #2387Any thoughts on "subless" SQ setup? Is it possible with mid level DLS seps and fully deadened front doors? Im using the small pioneer premier 8" shallow sub placed under the driver's seat. Im planning to get rid of it, get a processor and run fully active. Im only using a 4 channel amp and I dont want to buy another amp for the sub. Im using wideband tweeters that can go down to 800-1k hz btw.
Should I go subless? Or the expenses for another amp+wirings for my sub will be worth it? The sub Im using cant go deep and cant go loud btw, it is too small. And I have no space and no $$$ for shallow, deep, and loud 10inch subs like the JL's.
EDIT: Current setup is passive. My 4 channel amp powers the seps(with external Xover) and the sub
May 29th, 2017 11:07 AM #2388
Boss you can try to mount 8-inch shallow mount subs if possible. From there i think pwede ka na mag-dsp. Pero keep that in mind na kailangan mo ng another amplifier+wiring for the sub since channel 1 and 2 takes up the tweeters and channel 3 and 4 takes up the midbass since gusto mo mag-full active. What i've learned from tsikot and other forums is that pwede mo galawin yung HPF and see from there kung makukuntento ka na sa "subless".
May 30th, 2017 09:53 AM #2389
May 30th, 2017 11:16 AM #2390
Tesla Philippines
