Page 233 of 307 FirstFirst ... 133183223229230231232233234235236237243283 ... LastLast
Results 2,321 to 2,330 of 3070
    #2321
    Quote Originally Posted by joey36b View Post
    Sir, mukhang madalas ka masundan ni kumander ata ah. lol
    Wala ako kumander bro lol
    Sent from my D5303 using Tapatalk
    #2322
    mga bros, ano gawa ninyo pag tumatalon sub sa humps etc? :D
    aside from driving slow hehehe
    avoid roads with humps?
    but that would probably lengthen the trip.
    we just have to live with it.
    or, "tie it down" with hold-down clamps drilled into the metal.
    if you do not want to have to drill some holes, look at the inside of the trunk for ready-made holes. see if you can pass bungee ropes over the sub, and hook the ends into these holes in the trunk. you will probably have to look under the trunk covers, to find the holes. you will probably have to drill holes thru these covers, also. those bungee ropes are available from hardware stores and malls. if you need more tension, simply make a few knots with the rope.
    #2323
    Actually bro meron na nun rope na "garterized", tipong gamit sa school bag noon pero heavy duty from ace hardware. Wala lang mapagsabitan e.
    #2324
    look under the mats, po. look also at the sides of the trunk. most cars have holes, but are hidden by the side covers.
    Mar 2013
    #2325
    Madami humahabol pala lol. Jok!
    Ano auto nyo sir sedan or hatch?
    Type ng sub po?
    May nabibili na swivel type na hook na pwede mo bolt-on sa nakaexpose na bolt or screws. SM, handyman, diy or simpleng hardware store. U could try also sa motorcycle accs. shop hindi mawawalan. Alternative pa is aluminum or plastic drawer knob dami mapagpipilian (diy lang) kung may access sa back panel ng paglalagyan for screws.....3M velcro, alam mo sir ung plastic na nakatahi sa 3M matting na para hindi dumulas sa carpet? Sa handyman ko ata nakita meron. Non slip pads na malaki or malapad pwede rin (gaya ng pangdashboard), Dining top rubber mat, etc
    #2326
    Under the mats kasi parang insulation lang, tapos lawanit nakadikit
    Type ng sub po?
    Sedan vios 2006 lang bro
    Pero yun bolt idea mukhang uubra, try ko yun
    Thanks!
    Mar 2013
    #2327
    Thanks!
    From the trunk under the back glass or place ur rear speaker installed, may mga treaded holes na for 10 or 8m heads bolt na pwede mo kabitan, inner rear fenders kung baga eh tambol ang tawag ng latero magkabila hindi rin mawawalan. But if i were you sir magdrill ako ng kabitan sa rear brace ng cabin un ung nilalapatan ng backseat (sakto kung ano laki ng sub mo pa po).
    #2328
    Yun plano ko pabutasan bro. yun V shaped na pipe sa backseat. Sabay patungan ng amp
    #2329
    Baduy ba pag sa rear deck ilagay ang amp?
    #2330
    hindi naman, kung sa kailangan mo ng space sa trunk eh.... pakialam nila
    baka bilad nga lang sa araw.
audio set-up for beginners [continued]
