Results 1,021 to 1,030 of 4928
- Dec 2011
- 37
November 21st, 2015 01:40 AM #1021Sudden Acceleration
Sudden Acceleration
https://www.motorists.org/blog/drive...ive-you-crazy/
- Nov 2009
- 41
November 21st, 2015 07:24 AM #1023Sharing my personal experience with SUA with my manual car. After taking out the key, I pressed the clutch and changed to first gear due to weak hand brake. After grocery, I went inside the car, inserted the key, then started the engine and the car fast accelerated in itself even with hand brake engaged. I hit the end side of innova before I was able to step in the brake (I pressed the clutch first, not the brake due to panic). Innova was about 3 meters away. Parking guards rushed into the scene due to loud impact. I paid 17k for the repair of Innova.
I am not sure if in AT Montero you need to press the brake before you can start the engine. If not then above can be a common scenario since it is an old habit of older folks to engage in first gear when parking (I suspect in case of AT in D mode).
Those with AT Montero, maybe you can compare what will happen if you are already in D and start the engine with your foot on the brake and not on the brake. Or is this too scary to try? Will the car even start?
November 21st, 2015 08:27 AM #1024
^sa AT nasa P or N ang lever bago mo ma-start ang engine.
Bakit naka-engaged ka sa 1st gear during starting? Did you press your clutch before turning the ignition on?
Sent from my SM-N9005 using TapatalkLast edited by Gumusut_Amige; November 21st, 2015 at 08:30 AM.
- Apr 2012
- 3,469
November 21st, 2015 08:42 AM #1025Napagka imposible na PH models lang affected neto. Bakit sa ibang bansa walang SUA case ang montero?
November 21st, 2015 08:55 AM #1026
Magaling lang talaga sa marketing ang mitsubishi pero I think bulok sila sa quality control. Yung new montero safe na daw kasi may collision mitigation system na. Hehehe.
Tiba tiba na mga mag class suit nito. ABS CBN ba naman eh. Sorry nalang sa mga nadamay sa accidente ng montero, or kung may namatay man. What a responsible car dealer, Mitsubishi.
- Apr 2014
- 473
November 21st, 2015 09:42 AM #1027
November 21st, 2015 09:51 AM #1028
Bakit walang case ng SUA sa ibang bansa?? well Hindi naman ganun karami ang bumili ng Montero sa ibang bansa, di tulad dito sa atin sa PH na San damukal na buyers ang bumile nyan...... meron din ciguro sa abroad ng SUA cases pero very isolated and hindi na press release.......
BANNED BANNED BANNED
- Jan 2015
- 4,580
November 21st, 2015 10:19 AM #1029it is inaccurate to say na walang kaso ng SUA sa ibang bansa. it's not even Mitsubishi but Ford--
1) CASE NO. 2004-CA-000013
PEGGY T. STIMPSON and RALPH M. STIMPSON VS.
FORD MOTOR COMPANY, et al,
2) MANIGAULT ET AL., APPELLANTS, v. FORD MOTOR COMPANY, APPELLEE, ET AL.
[Cite as Manigault v. Ford Motor Co., 96 Ohio St.3d 431, 2002-Ohio-5057.]
3)JONES v FORD MOTOR COMPANY
Record No. 010136, March 1, 2002
4) KNOSTER v FORD MOTOR COMPANY
No. 05-3355
5) U.S. 2nd Circuit Court of Appeals
Jarvis v Ford Motor Company
United States of Court of Appeals
For the second Circuit
August Term, 2000
(Argued: May 14, 2001 Decided: February 07, 2002 Corrected: February 11, 2002)
Docket Nos. 99-9405 (L), 00-9215 (CON)
November 21st, 2015 10:30 AM #1030
