Page 122 of 307 FirstFirst ... 2272112118119120121122123124125126132172222 ... LastLast
Results 1,211 to 1,220 of 3070
    Apr 2012
    #1211
    Quote Originally Posted by D3nb3r View Post
    That's ok, you'll never know baka bukas makalawa meron na naman mg benta nang amps nila.
    meron yan sir d3nb3r, lalo malapit na pasko maraming darating na good deals merong DLS A7 5ch amp binebenta sa fb ng car audio sale/swap kaso walang kontak yung seller it looks old na pero nasa 30k pa rin...
    Mar 2012
    #1212
    good to know sir Monty but 30k is way above my budget for an amps. Budget meal lang kaya ko hehehe. I'm thinking of a Rockford Fosgate R400-4D lang.
    Mar 2012
    #1213
    Curious lang mga sir. I know that the bass frequency is 20Hz and below and that is the subwoofer's area.
    My question is more in the component set. Given the frequency response of a component speaker A of 35Hz-21kHz and component speaker B has 60Hz-20kHz, does this mean that component speaker A will have better bass sound? Or, we also have to factor the materials and technology that has been used in the development of the speakers(w/ respect to near bass frequency)?
    Please enlighten me. thanks.
    Aug 2010
    #1214
    Q: Given the frequency response of a component speaker A of 35Hz-21kHz and component speaker B has 60Hz-20kHz, does this mean that component speaker A will have better bass sound?
    A: Nope
    Q:We also have to factor the materials and technology that has been used in the development of the speakers(w/ respect to near bass frequency)?
    A: Yes. Engineering is expensive though, physics is a better indicator of bass. Larger midbass = more air moved = more bass.
    Recreating bass or midbass frequencies is simply the art of moving air. Frequency response is a bad metric in general since manufacturers quote them vaguely. You see, all of these component speakers' midbass can technically reach up to 20hz once you remove the filters. BUT, you can't hear it since the output is too low.
    Mar 2012
    #1215
    Quote Originally Posted by jhnkvn View Post
    A: Nope
    Got it sir jhnkvn. thanks.
    So if there are 2 speakers with similar(but not the same) specs and only differ in woofer diameter like lets say a 6.5" and a 5.25", the speaker that has a wider surface area cone will be most likely have a better bass sound since it will move more air than the other.
    Aug 2010
    #1216
    Yes. There's a difference between extension (how low it goes) and output (how loud it goes). Truthfully, you ideally want all two. But the more important one is output. What's the use of extension if you can't hear or feel it.
    Feb 2011
    #1217
    Had a Jazz before and to save space, what the installer did before was to create a false floor. Since malilim naman ang trunk ng Jazz they added an additional layer on top of the original flooring so the amp and sub is becomes an integral part of the flooring. Search mo na lang sa KAC my rides section
    Quote Originally Posted by enargie View Post
    Sir may I ask for advise for the right size of subwoofer speaker for honda jazz. Since maliit lang naman ang interior nya and I'm more inclined on sq route, would an 8" subs will suffice my need. As of now I already installed 2-way seps powered by my HU only, I'm planning to install an amp to power the seps together with the sub but need to know the ideal size of subs based on the size of my car. Thanks
    Posted via Tsikot Mobile App
    Apr 2008
    #1218
    May tanong ako. May problema yung stock head unit ng 2011 Santa Fe namin. Ayaw nya magplay ng kahit anong CD, lalabas lagi "bad disc", ganun din dun sa SD card slot, although tinatanggap naman niya ang GPS map data SD card. Yung TV niya 1 channel lang ang natatanggap. Gumagana naman ng maayos ang tuner at aux-in. Ano kaya problema nito?
    Sent from my GT-I9100 using Tapatalk 2
    Aug 2010
    #1219
    Quote Originally Posted by GTi View Post
    That's probably the head unit's "mother" board na mismo. In theory, it might just be the CD mechanism if lagi bad disc yun CD but since the SD slot is also affected, I'll suspect that it's the board itself.
    Hindi ba pasok sa warranty ni Hyundai PH? Since that's going to cost a lot for repairs (almost brand new cost na yan)
    Oct 2008
    #1220
    Tanong ko lang, ganun ba talaga "ka-pangit" ang sounds ng stock headunits kaya need palitan if you want better sound? hindi ba puedeng lagyan na muna ng amps at change stock speakers? Ok naman kasi sakin yung tunog nung stock HU ng Vios 2013 pero yun lang need ko ilakas yung volume para may bass or mapuno nya ng sound yung loob ng car. Sa ganitong case ba ng listening style ko, palit HU ba ang better route?
audio set-up for beginners [continued]
