Page 91 of 307 FirstFirst ... 4181878889909192939495101141191 ... LastLast
Results 901 to 910 of 3070
    Aug 2010
    #901
    Butyl is rubber. Asphalt.. is well.. asphalt.
    How to tell them apart? Hard to do. I mean you don't want to light your doors up right?
    Best bet is to simply start by purchasing stuff that you're sure is made of butyl.
    Based on your posts dito sa tsikot and sa KAC. Di ko talaga alam if your installer is recommending you for a second layer (Tsikot) or not (85% na daw yun one layer -- KAC).
    Apr 2008
    #902
    Sir jhnkvn,
    I have a question regarding power handling ng head unit, I recently had a Pioneer DEH-X2650U installed on my Suzuki Swift, I want to change both front and rear speakers, for now im not planning to get an amp. When i do choose a speaker will speakers with 2ohms work well with the head unit? or should i use 4-8ohms? I plan sana to get a JBL GTO608c for front and a JBL coaxial sa likod.
    Thanks
    Aug 2010
    #903
    Quote Originally Posted by Rakenrol101 View Post
    Sir jhnkvn,
    Thanks
    Try to get the 4ohms as much as possible. As every electrical engineer knows, ohms is a measure of resistance -- in this case, the flow of electricity. The lower it is, the less resistance there is. Problem is, most head units aren't stable at 2 ohms. However, there's no problem in using 4 ohms and 8 ohm drivers.
    The good thing here is that most car audio drivers are 4 ohms and home audio, 8 ohms. Where the hell did you get the 2 ohm driver? :O
    Apr 2008
    #904
    Quote Originally Posted by jhnkvn View Post
    Thanks for the reply sir, I called Perfect Circle Banawe and they said that the GTO series are 2ohms? and im trying to research if my head unit is capable in running that
    Jun 2011
    #905
    Sir jhnkvn,
    Thanks
    wala nang GTO 608C sir, GTO 609C na ang pumalit, SRP is 4,800 pesos sa Perfect Circle (Authorized Distributor)
    May 2009
    #906
    may shop/s ba kayo na mare recommend that
    are good in installing deadeners? balak ko magpalagay this weekend
    sa front doors ng revo ko muna at kung effective siya eh baka lahat
    ng door panels eh palagyan ko na....nagbabasa basa pa ako sa
    sound setup kaya sound deadening muna uunahin ko hehe....salamat!
    Aug 2010
    #907
    Quote Originally Posted by brod78 View Post
    A lot of installers know how to install deadeners naman. It's not a skill-intensive task and the most you need is common sense and a heatgun -- some do it DIY in fact.
    Sep 2009
    #908
    Bili ka na lang heatgun and deadening materials tapos DIY like me. Mas maganda pag ganun kasi ikaw didiskarte kung saan panel pa ng auto ang kailangan dagdagan kesa naman pabalik balik ka sa shop tapos doble doble gastos. Yung sa akin binili ko lang dati yung deadening for 150 petot yata per meter kumpara sa mga shop na more than 1k minsan. Sarap pa ng pakiramdam pag natapos mo na yung project dahil atat ka na subukan kung ano ang improvement sa sounds mo.
    Sent from my iPad using Tsikot Forums
    May 2009
    #909
    thanks jhnkvn & wezz.
    unfortunately i think im not yet prepared to tinker with a car so
    i've asked a quotation from mickys autosound and it's 4.5k for
    the front doors only....a bit expensive???
    Nov 2007
    #910
    Pa quote ka din kay Jeff Tan of araneta cars baka mas makamura ka dun bait un si boss jeff
audio set-up for beginners [continued]
