Results 121 to 130 of 287
October 24th, 2018 08:50 PM #121
*ninja
Nagbabawas ba nang coolant or may leak sa sahig? If yes, sign of water pump failure yan.
I forgot how much it cost for water pump replacement since it was a mere decade ago.
October 25th, 2018 02:45 AM #122
- Oct 2018
- 8
October 25th, 2018 04:21 AM #123
- Dec 2013
- 680
October 25th, 2018 09:01 AM #124Any of you guys have an idea how long an engine can run without coolant before it overheats? The plastic drain plug of my radiator is broken/leaks and the radiator cannot hold water in longer than 3mins(parang gripo talaga). Sad thing is the plug broke in two such that half of the screw is stuck inside(handle broke off) so i cannot plug the leak...not sure kung aabot pa sa shop mga 20mins away and i dont want to risk overheating the car. Thanks!
October 25th, 2018 09:06 AM #125
- Jul 2013
- 2,450
October 25th, 2018 09:22 AM #126
October 25th, 2018 09:23 AM #127
October 25th, 2018 10:01 AM #128
It will just take 3-5 minutes for the engine to overheat ... What you can do is drive to the shop 3-4 am ... Stop every five minutes and let engine cool for 30 minutes then drive again another 3 minutes and let it cool 30 minutes ... Repeat until you reach the shop ... Or you can try to refill the radiator every 2 minutes but it would be risky and you might get scalded ...
Or you can have mechanic do home service and remove radiator then bring to radiator repair shop ...
Had car towed on flatbed before for 1,500 to fix a broken hose worth 80 pesos plus 300 labor ...
- Jul 2013
- 2,450
October 25th, 2018 11:10 AM #129Most drain plugs are made of plastic. Kung ganun ang sa sasakyan mo, on the spot, pwede mo mapasikwat sa isang mekaniko yun.
- Jan 2013
- 1,851
October 25th, 2018 11:19 AM #130Not a mechanic here. Naisip ko lang, kung may butas radiator mo, and your only goal is to bring it Sa talyer, di kaya pwede yung mga pantapal na heat resistant, Yung parang tape na parang foil. Pansamantala lang. Para madala mo sa mekaniko.
Na putulan ako dati ng throttle cable sa old pajero ko. Nasa hiway ako nun. Dinugtong ko muna yung cable using para cord para lang mauwi yung kotse.
Sent from my ONEPLUS A3000 using Tapatalk
Tesla Philippines
