Page 29 of 29 FirstFirst ... 192526272829
Results 281 to 287 of 287
    Oct 2015
    #281
    Ano kaya po problema nito? Had the alternator replaced but now the car is overheating.
    -Honda Civic 1997 manual VTI
    -radiator has been replaced on November 2018 to a 2 row one
    -initially the suspect was the thermoswitch so nirekta ng mechanic na constant spinning nung rad fan (bibili ako ng new thermoswitch dun sa malapit na autosupply sa amin pero out of stock sila on that day) so nakarekta sya hanggang day off ko bukas sa paghanap ng thermoswitch
    -initially I thought it was the aircon affecting the rad fan in some way pero kanina kahit di ako nag aircon nag OH sya
    -bukas I'm planning to buy a thermoswitch and a thermostat hopefully that will fix it
    -chineck ko kung may symptoms ng broken head gasket, so far wala naman milkiness sa oil cap, white smoke sa exhaust or discoloration sa reserve
    -now one thing I've noticed kanina, yung isang pulley sa may ilalim ng alternator, baka namamalikmata lang ako parang yung belt lang gumagalaw at di sila synced ng pulley. Could this be the waterpump?
    Your feedbacks would be most appreciated.
    Forgot to add, overheating started last Saturday
    #282
    This is unfortunate, when you fixed something that is not damaged and now is broken...
    This is good information for those who are new to cars, leave the radiator as it is if you are using coolant. Follow manufacturer's recommendation for its interval when to replace the fluid.
    true bro, reason kung bakit naka coolant palagi ay para maiwasan ito.
    oh well lesson learned for only less 15k pesos hehehe
    #283
    that radyeytor cost 15 K...?!!
    #284
    labor and materials bro
    radiator overhaul
    orig thermostat and thermo switch
    orig aux fan
    taiwan radiator
    china thermo switch
    gmb water pump
    toyota coolant
    orig upper and lower radiator hose
    di ko na maalala iba, nasa previous pages lang hehehe
    #285
    radiator overhaul
    orig aux fan
    taiwan radiator
    china thermo switch
    gmb water pump
    toyota coolant
    "kawawa ka naman."
    ah well.. the price of DIY...
    #286
    "kawawa ka naman."
    ika nga ni alanis bro ..
    you live, you learn hehehe
    pwede nako bumili ng gas guzzler na di toyota LOL
    #287
    i feel.
    my most expensive auto education, was from an ex-taxi na semi-orphan that i bought and fixed up, decades ago.
    never again.
    nunca mas.
    if ever i have to fix up an ex taxi again, it'd be a... toyota!
Radiator / Overheating Problem
