Page 3 of 29 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 287
    Oct 2013
    #21
    Thanks mga sirs sa inputs nio. At least may idea na ko ng pwede cause ng overheating
    baka may kakilala kayong naghohome service na mekaniko. ayoko na sana ibyahe. Guadalupe, Makati Area
    Sent from my SM-J700F using Tsikot Forums mobile app
    Oct 2013
    #22
    Quote Originally Posted by mina_nuka View Post
    What was the last thing performed to the engine that might involve the cooling system?
    Às per this diagram
    toyota avanza thermostat - Google Search
    The system should have been bled at two places if at any point the coolant was low or was drained and refilled
    Last thing na ginawa ko for cooling system is nagchange ako ng motor ng fan ng radiator last year
    May 2011
    #23
    Quote Originally Posted by misterioman View Post
    Before doing anything or having anything done to it, top off with antifreeze/coolant and bleed the system
    May 2013
    #24
    Kung nagbabawas ng tubig/coolant at walang leak, I would replace the radiator cap.
    #25
    Quote Originally Posted by andsmv View Post
    i have a nice collection of near-brand-new caps.
    but everytime, the problem turned out to be "something else".
    we live and learn.
    May 2011
    #26
    we live and learn.
    Been guessing eh😁
    Dec 2009
    #27
    What is your reference level for the coolant fluid?
    The coolant fluid container is marked F and L
    If your reference is above F then its normal because F should be maximum level of the fluid. As in the proper level should be F and below for the coolant fluid, while F and above should be air
    Why that should be the case? Build up in heat result in greater pressure which push that fluid level above the F mark. If you filled the the coolant container up to the brim, then that will be indeed the case, there will always be reduction in fluid level, as long as its not below L mark, then the coolant level should be ok
    If you carefully inspect the coolant container, there is an overspill hole on top. That takes care of excess fluid upon pressure build up, it discharge excess coolant fluid due to pressure expansion
    The best practice in filling up coolant is up to F mark level only
    Sent from my GT-P3110 using Tsikot Forums mobile app
    May 2009
    #28
    sa simpleng pressure test e masshoot siguro ang problema nyan.......
    kahit yung bicycle pump, tire valve, silicone sealant at kung may extra ka na radiator cap or yung pinagpalitan mo na rad cap pupwede na. google nyo po kung pano gumawa ng simpleng aparato para sa pressure test.
    Oct 2013
    #29
    Update mga sirs
    So, last night pinuno ko ng tubig yung expansion tank and radiator. pinaandar ko yung makina for 40mins with aircon. di naman tumaas temp. Sabi ko sa sarili ko pwede ng mabyahe to from Guadalupe to Banawe (Jorge Radiator).
    nakarating ako sa banawe (8am), no aircon. baka itirik ako.
    ang naging solution ni mekaniko, overhaul ng radiator.
    Ok na sia mga sirs. d na sia nagooverheat kahit tirik and araw and may Aircon. salamat sa lahat! The best talaga sa Tsikot!
    #30
    Been guessing eh😁
    well, the radiator cap is the easiest and cheapest suspect to evaluate...
Radiator / Overheating Problem
