Page 7 of 14 FirstFirst ... 34567891011 ... LastLast
Results 61 to 70 of 135
    #61
    ^ Honda Type 2 Long Life Coolant is blue and it's not listed. At the very least, that chart is probably outdated.
    This pretty much sums up what my point was. You can probably mix certain types together with little to no cause for concern but doing so will entail varying degrees of guesswork. You can go through that trouble or you can just pop into your car dealer and buy a jug of OEM coolant specifically for your vehicle and let that be the end of it.
    Yes, outdated. And it doesn't include Evans Waterless. One you can't mix w/ any other.
    Jan 2009
    #62
    EDIT: Replied too soon based on something I misread.
    #63
    pwede naman fully drain existing coolant. then wash out the remaining by 3-4x distilled water refill then drain after kew KM or few minutes idle? after doing these steps, pwede na any color of coolant diba? parang mas maigi ito dun sa mga auto na hard to find yun mga coolant nila.
    #64
    If one is able to do total block drains of old coolant, say post-engine-overhaul, & wants no more coolant flushes & changes EVER....go EVANS Waterless.
    *This can't mix w/ waterbased coolant.
    Waterless Engine Coolant - Jay Leno's Garage - YouTube
    Benefits below:
    Apr 2014
    #65
    Benefits below:
    It doesnt degrade?
    What kind of chemical is that? Half life of thousand..
    #66
    Quote Originally Posted by chronicle View Post
    It doesnt degrade?
    Nope...& you can drink it & not die after, too.[emoji4]
    #67
    at magkakano naman yan bro? ^_^
    #68
    Locally? You may ask em, g'ninj.
    Evans Waterless Coolants PH
    #69
    dapat pala bro meron sila nito, para di na need overhaul LOL
    https://www.amazon.com/EVANS-Cooling...ZX4C5HB6X052NK
    #70
    It's still ideal & best applied to a drained block.[emoji106]
Coolant...
