Results 51 to 60 of 135
June 21st, 2019 09:05 AM #51
The color is just a dye. Any coolant will do.
Safest answer is go to casa and buy a coolant specific to that model.
However, some coolants are rated long life some are standard.
June 21st, 2019 09:30 AM #52
June 21st, 2019 03:56 PM #53
In my limited experience/knowledge:
Color of orange(?)/pink(?) is Toyota bro... Better to use coolant with the same color, or buy it from the car dealer....
Green is Honda;- think other Hondas are using blue.
Blue is Mitsubishi/Hyundai/Subaru...
Where does Prestone's neon green/yellow go with?
June 21st, 2019 04:18 PM #54
The color signifies the ingredients used to formulate it. It does not necessarily mean that like-colored coolants from different manufacturers can be mixed.
Well, maybe they can. But if you want to be absolutely sure that it's going to be compatible, use whatever is recommended in the manual.
Do note that the cooling system is one big electrolysis machine and the coolant stays there for years on end. As it is, the environment is ripe for chemical reactions to happen. It's only the chemical make-up of the coolant that's stopping that. However, using the incorrect coolant may cause chemical imbalances that can induce corrosion.
- May 2019
- 312
June 26th, 2019 06:56 PM #55^ Totally agree! Besides you change your coolant every 4-5 years, so why skimp?
June 26th, 2019 06:58 PM #56
You can mix prestone with any color of coolant.
Been doing this for years now and so far so good.
- Feb 2019
- 27
June 30th, 2019 02:32 PM #58Thank po sa mga sagot. Great help talaga kayo.
So safe lng pala.
I'll buy the coolant with the same color (orange) and pour it to the remaining coolant.. Ill also consider going to toyota hehehe
Sent from my A1601 using Tapatalk
June 30th, 2019 03:03 PM #59
June 30th, 2019 04:39 PM #60
^ Honda Type 2 Long Life Coolant is blue and it's not listed. At the very least, that chart is probably outdated.
This pretty much sums up what my point was. You can probably mix certain types together with little to no cause for concern but doing so will entail varying degrees of guesswork. You can go through that trouble or you can just pop into your car dealer and buy a jug of OEM coolant specifically for your vehicle and let that be the end of it.
Tesla Philippines
