Page 10 of 14 FirstFirst ... 67891011121314 LastLast
Results 91 to 100 of 135
    #91
    opted not to use it na lang. daan na lang ako sa suki ko one of these days para bili ng bote.
    thanks mga bro!
    para ring expired food.
    just one trip to the loo, and you will be rue-ing the day you ate it...
    Jan 2009
    #92
    Those particulates may be silicates.
    Silicates do have a life, and it's a short one - two years. If left longer, build up inside the radiator begins, and the silicates actually contribute to cooling system problems. Silicate drop out occurs after the coolant has been "spent", and the inhibitors drop out of solution. Silicates are blamed for deposit build up in radiators and heaters, causing engine overheating and poor heater performance. Once the silicates drop out of solution, dissimilar metal corrosion is no longer suppressed, and metal components begin to deteriorate.
    Silicates are deemed to be abrasive in a cooling system, and are blamed for premature water pump seal failure.
    Source: Antifreeze
    #93
    Source: Antifreeze
    Hinde pa ba silicate free mga coolant ngayon?
    Jan 2009
    #94
    If it says that it is silicate-free. There are still "regular" low-silicate coolants available.
    And I did say "Those particulates may be silicates."
    Otherwise, unless the coolant container was contaminated through other means, what else can it be?
    #95
    Source: Antifreeze
    thanks for sharing bro
    mas maganda talaga bago lagi coolant
    ill stick with my 20-30k km interval
    Sent from my RMX2020 using Tapatalk
    May 2019
    #96
    Don’t mix coolant of different colors. I personally use Zerex Asian Blue or Honda type 2 for my Element, and just regular green Prestone for my Sonata.
    Jun 2017
    #97
    ok ba to voltronic coolant?
    Apr 2012
    #98
    Quote Originally Posted by troytin20 View Post
    Noted sir dapat talaga ma flush kung magpapalit ng ibang brand/color no, paano ba nila iddrain yung coolant na nasa engine? Para sana walang matirang luma
    i did DIY coolant flush following this vid. so far ok naman.
    Paano Mag-Flush ng Cooling System ng Montero Sport | DIY Tutorial - YouTube
    #99
    ^ not really a knock on him pero nagtataka lang ako medyo ayaw nya ata gumamit ng oem fluids pati sa iba niyang vids.
    Pero informative nga mga diy projects niya sa mga sasakyan irregardless of different makes he has tackled.
    I wouldn't switch on the AC to warm up the engine, the spinning radiator fan will remove the heat build up in the cooling system. this will lengthen the time to open "thermostat"
    coolant change every year is rather excessive.
Coolant...
