Results 31 to 40 of 135
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 9th, 2007 11:51 PM #31medyo mahaba but it should answer a lot of questions.
http://www.eetcorp.com/antifreeze/antifreeze-faq.htmLast edited by userfriendly; October 10th, 2007 at 12:09 AM. Reason: changed entire post
BANNED BANNED BANNED
- Aug 2007
- 999
October 10th, 2007 05:54 AM #32^ Thanks doon sa link.
So ang mali timpla pala ng coolant eh pwede makasira ng water pump.
Ilan kms or months dapat palitan ang coolant?
Pag may coolant na ba hindi ba nagbabawas sa radiator. Kasi sa tubig nagbabawas after 2 weeks.
usually ilan years bago ma-overhaul radiator?
Ano yung ok dito sa pinas na pre-mixed coolant?
Kung marami na scales, rust eh pwede pa ba ipalinis ang radiator para mawala?
Thanks
Tsikot Member Rank 5
- Nov 2003
- 3,848
October 10th, 2007 08:14 AM #33kung nagbabawas radiator mo with water, it will act the same with coolant.
normally between 20-40k kms for older cars but most new cars have extended drain intervals now for the new coolant.
- Aug 2007
- 999
October 10th, 2007 05:17 PM #34
October 10th, 2007 06:09 PM #35
*everester62: Use the coolant the casa tells you to... like speedyfix says, masama ang paghalo ng coolant... that's why they add coloring, to warn you not to mix them.
*suv: Maraming possible causes: puwedeng maluwag yung hoses o may pinhole na leak na di tumutulo unless high rpms. Puwedeng iniinom ng makina at high rpms (tignan mo kung may puting usok...) o may problem sa water pump.
Kung may tagas na ang head-gasket mo, may chance na pumupunta ang coolant sa cylinder. Puwede mong i-check ito sa pagbukas ng radiator cap (habang malamig... huwag gawin pag umaandar na ang makina...) at pag-re-rev ng makina... kung bumubula, possible sign yun na may problem ka sa head gasket.
- Aug 2007
- 999
October 10th, 2007 07:04 PM #36
- Oct 2006
- 128
October 11th, 2007 01:48 AM #37radiator looks like it's full of mud... and it's losing water every few hundred kilometers
based on this i think there is an engine problem, wherein oil mixed with water in the radiator? when u rev it up, there is like pockets of air coming out your radiator? it easily overheats? whats the color of the emissions? fix ur engine as it is failing... needs some overhaul if not fixed early
October 11th, 2007 04:08 PM #38
*suv: normal yung white smoke pag gabi... that's from the added water vapor in the air going through the engine and in the exhaust.
Without seeing your car, it'll be hard to diagnose... best to bring it to a good mechanic to have everything checked... and then, after that... bring it to another one to confirm... dalhin mo na kay bro. speedyfix... hehehe...
- Aug 2007
- 999
October 11th, 2007 06:49 PM #39
October 11th, 2007 07:01 PM #40
PM mo si speedyfix to ask for his address.
It's a fair bet you have no gasket problems... likely you have issues with your radiator and/or hoses. If your hoses are a bit old, best bet is to replace them all anyway.
Mahirap talaga ang cooling problem... one thing affects another, which affects another... at one point it took me over a month to diagnose and fix all the cooling problems on my 626 (repaired radiator, replaced hoses, replaced water pump, replaced auxfan... etcetera).
Tesla Philippines
