Results 51 to 60 of 140
- Dec 2015
- 27
June 26th, 2016 03:51 PM #51
June 26th, 2016 04:13 PM #52
MT is cheaper to maintain than AT notion.
Does it still apply today?
How often do you replace transmission fluid sa MT?
Like ATF/CVT fluid for ATs every 40K KMs ang palit.
- Aug 2012
- 2,767
June 26th, 2016 04:46 PM #53
June 26th, 2016 08:34 PM #54
Please do enlighten me, between EDSA rush hour driving and cruising on the highway, when exactly do you use heel and toe?
And aside from cheap sports cars like the 86 and MX5, most of today's affordable manuals have pedal placements unsuitable for heel and toe because the pedal height for the brake is much higher than the accelerator.
Heck, I drive mountain roads on a regular basis, and don't find the need to use heel and toe - you can always brake then rev match separately, after all, noone is timing you.
- Jun 2016
- 97
- 53,883
June 26th, 2016 11:07 PM #56traditional AT uses metal gears with fixed gear ratios.
CVT uses belts that slide over a... whatchamacallit... reverse-spindle-type of surface (a "variable diameter pulley"), resulting in a practically un-stepped gear ratio.
google it, sir. it can explain it with diagrams and all, a lot better than i can.Last edited by dr. d; June 26th, 2016 at 11:10 PM.
June 26th, 2016 11:40 PM #57
Manual gets my vote. I "feel" the car better when it's a manual
- 53,883
June 26th, 2016 11:43 PM #58
- Jun 2015
- 2,751
June 26th, 2016 11:46 PM #59Learned to drive MT but I prefer AT now. I can concentrate more on what's happening on the road rather than worrying if I'll stall or if I'll roll backwards on an inclined street.
Kaantok nga lang ang AT pag long drives.
Tapatalked
- 53,883
June 26th, 2016 11:50 PM #60shifting MT becomes almost automatic, after one has driven MT long enough..
Tesla Philippines
