Results 1,121 to 1,130 of 2049
- Apr 2014
- 38
February 28th, 2015 03:53 PM #1121I don't think it was raised, more like maintained. I think the lifter just ensures the tires don't hit the roof of the wheel well in case you run over a hump too fast, or in my case, that it doesn't sag. I really like the Wigo's profile, the lifter is just a temporary solution until I can find better aftermarket replacement shocks for it.
but my concern is, are we not going beyond the weight limit of such a smaller and cheaper car? will the car go into premature failure because of the weight of the passengers it is being subjected to?
Probably. What is the weight limit anyway? I can't find it on the user manual.
- Jun 2012
- 4,447
- 53,883
February 28th, 2015 04:44 PM #1123i do not know. i tried to look for it also. manual.. innernet.. nada. parang state secret yata.. but someone did mention, 4 adults or 5 filipinos.. whatever that means.
and yes, even without modifications, the wigo is matagtag. dahil mataas ang recommended tire pressure, and also because it's got a short wheelbase.. can't soften even light bumps..
- Feb 2015
- 4
February 28th, 2015 05:03 PM #1124Thanks sa mga replies. height ko nasa 5'8 weight nasa 175kg. 2 adults lng naman kaso minsan pag may lakad barkada 5 adults with almost the same weights kami hehe atleast nagka idea ako about sa lifter. Wigo plng kasi kaya budget namin tska matagal pa naman sa nov pa cguro.
yaris or vios sana tlaga gusto ko kaso alanganin sa budget.
hindi ba hirap sa incline ang wigo AT? Like sa tagaytay highlands?
- Apr 2014
- 38
February 28th, 2015 05:03 PM #1125Nope.
Well, yes, it is, especially if you strictly follow the 36psi tire pressure recommendation indicated on the side of the doors, which is "matagtag" na even without the lifters. But, I use 34, I always have, and the ride quality isn't any different from what it was before.
- Apr 2014
- 38
February 28th, 2015 05:18 PM #1126Kaya yan
We use the car every weekday papasok to Makati, 3 adults, and then sometimes 4 adults pauwi. But then again, I have lifters. Nyehehe preparation na din when the day comes (if it does) na magpalit ng mags to 15 inch. :D
hindi ba hirap sa incline ang wigo AT? Like sa tagaytay highlands?You can take it all the way up to Baguio if you want.
- Mar 2014
- 901
February 28th, 2015 05:45 PM #1127Hello.... Yung lifter pala ang sagot.
May I ask, yan ba yung idinadagdag sa gitna o shafting ng shock absorber?
Ang taas ng tire pressure mo. 36psi talaga? Samantala sa mga sedan cars na drive ko usually 27 - 28 psi ang recommended tire pressure nila. At nasa manual nila nakalagay at door side reminder. Usually, 30psi tire pressure ang ginagawa ko. Ang Mitsu Lancer 89 (singkit type) 28psi. Eto naman gamit ko ngayon Honda City 99 model (SX8 Type) 27psi.
Mungkahi lang, try mo 28psi o 30psi sa lahat ng wheels mo. Observe mo lang kung san tire pressure sya hindi maging matagtag.
Sent from my Starmobile UP+ using Tapatalk
- Feb 2015
- 4
February 28th, 2015 05:50 PM #1128
- Apr 2014
- 38
February 28th, 2015 07:04 PM #1129May I ask, yan ba yung idinadagdag sa gitna o shafting ng shock absorber?
Really baguio? sa AT un? mas mataaa ba ung going baguio kesa sa highlands? Kht 5 adult passengers?
- Mar 2014
- 901
February 28th, 2015 07:29 PM #1130
Tesla Philippines
