Results 2,041 to 2,049 of 2049
- 172
May 10th, 2021 11:49 PM #2041guys question lang for Wigo E MT 2nd hand
ano magandang brake pads, bendix ba? manipis na brake pad, stock pa yata ito.
anong gear oil ang dapat gamitin? 50k na mileage
sa engine oil 5w 30 mineral ok na ba? kailangan toyota brand?
and also coolant?
- Jun 2005
- 3,774
May 11th, 2021 01:12 AM #2042Ayus naman bendix. Of you can get advics or akebono mas okay daw yun.
Oil, just follow what the manual recommends.
Coolant, buy the premixed from thr casa. Its cheap. 350 per 2 liter bottleSent from my MI MAX 2 using Tsikot Forums mobile app
- 53,883
May 13th, 2021 10:11 AM #2043my 2014 wigo AT's CEL turned on, and wouldn't turn off. otherwise, everything works fine.
odometer's 51K only. last oil change was feb 2020, just before covid quarantine. total mileage since is less than 2K km.
before i bring it to the casa, would anyone have a similar experience and what did it turn out to be?
thanks.
May 13th, 2021 10:21 AM #2044
scan natin bro
baka sensor lang yan
Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
- 53,883
May 13th, 2021 11:41 AM #2045
May 13th, 2021 12:03 PM #2046
di pa natin alam bro, di pa na scan eh [emoji28]
pwede MAF, oxygen etc.
madalas maf lang and linis lang contact cleaner ok na
- 53,883
September 16th, 2024 05:16 PM #2047just recently, my 2014 wigo with 68K km,
the breaks are kinda mushy.
before, when i step on the pedal, it breaks upon first resistance, as it should be.
now, when i step on them, there is an initial resistance that kinda sinks first, before the breaks solidify and finally take. no bounce or springiness. no, it don't feel like air in the system.
brought it to the suki, where we had the rear shoes replaced, as they were already thin. ***
it still breaks like in two parts. the front pads are still thick. no leaks anywhere. no loss of liquid.
i am thinking, is it the master cylinder? assuming still smooth bores, overhaul kit or assembly replacement?
magkano kaya, overhaul kit versus master replacement?
haven't done this for many years...
btw,
my CEL above? it disappeared after a day or two, and never came back again.
*** it seems, the rear shoes are of two sizes. mine are 1gen and are kinda small. the first set the talyer had on stock, was appreciably larger and, i am guessing, for the more recent wigos. FYI.Last edited by dr. d; September 16th, 2024 at 05:30 PM.
September 16th, 2024 05:38 PM #2048
- 53,883
September 18th, 2024 08:45 AM #2049update.
went back to my talyer, money burning a hole in my pocket, ready to replace the master cylinder.
they simply bled the breaks.
car's brakes now back to normal.
i was so happy when they didn't charge me ("back job"), despite the fact that they provided the break fluid, that i gave the guy two hundring bucks.
