Results 2,391 to 2,400 of 3070
June 5th, 2017 05:06 PM #2391
Is it possible? Of course. Kahit entry-level pa yan. However, the key to achieving a good sub-less setup isn't with fully deadened front doors but by trying to achieve a truly rigid enclosure through the use of many techniques (deadening, inserting foam, etc.) . Hindi lang yan puro deadening (case to point: my doors have like 3 sheets each; still rattles) that's why a lot of people who truly want to go sub-less cut their doors to accommodate a miniature enclosure in it (ex. Bewith midbass). It's like finding a bookshelf speaker and just slapping it sa doors.
The reason for this is that vibrations is your worst enemy as even a small rattle reduces your decibel output by a lot. That's why a 8" midbass doesn't sound as good as a 8" subwoofer. Drivers-aside, it's usually the enclosure.
Will it be worth it? Will depend on your taste. My recommendation is to first test it out. I would recommend a 50hz cutoff. Just remember to play around with the EQ and the slopes to get ample low-end. Don't be afraid to pump it up. Most midbass drivers can handle much more than you think.
June 5th, 2017 05:08 PM #2392
And you'd be surprised how creative people can be in making subwoofers. For example, I really like the recent center mount subwoofer Jonz of Simplesounds made for a client (Simplesound Car Audio - Cainta - Automotive Parts Store | Facebook) Check out that May 23 build log!
June 5th, 2017 05:11 PM #2393
*crazy
I would NOT recommend amplifying those 4" speakers as 4" speakers don't really output a lot of bass because of their limitations and many regard 4" to be the realm of "mids" than "bass". You really need the additional wattage on bass producing drivers -- mids and tweets practically sip power lang.
To be honest, I would recommend a subwoofer to really appreciate a setup using 4" speakers. That way your subwoofer can pick up the bass region. Would I prefer coax? Nope. I'd still nod in making a 6" hole in your doors to accommodate a separate component than a coax. Fact is: you shouldn't be hearing vocals coming from your hips, dapat ear-level yan dapat.Last edited by jhnkvn; June 5th, 2017 at 05:15 PM.
- Apr 2017
- 45
June 7th, 2017 08:26 PM #2394
- Apr 2017
- 45
June 7th, 2017 08:42 PM #2395Thanks sir jhnkvn. Mukhang mas hassle at mas magastos pa pala yung enclosures na ganun kesa mag dagdag ng amp at wirings haha
pero gusto ko yung ganun, interesado ako sa ganung setup.
And dun sa box na gawa ng simplesound, parang ganun yung sakin dati before ako mag underseat. Ok talaga sana tas downfire pa, kaso yun nga lang naka buka yung legs ng uupo sa likod haha. Hirap talaga di na ako na contento sa location ng sub hehe, will try sa footwell ng passenger rin. Paglaruan ko muna yung HPF ng seps hehe.
- Aug 2015
- 36
June 8th, 2017 04:11 PM #2396
- Jun 2017
- 2
June 8th, 2017 07:26 PM #2397Guys, baka may idea kayo about sa amp na autosonik aa6900, been doing google search, but no idea of the company, reviews of the amp itself. Ano info about the amp, bad or good...TIA
Sent from my SM-N920C using Tsikot Forums mobile app
- Aug 2012
- 2,767
June 8th, 2017 08:56 PM #2398Made in Korea according to this:
AUTOSONIK technology AA69
Sent from my ASUS_Z010D using Tapatalk
- Apr 2017
- 45
- Mar 2013
- 220
June 9th, 2017 04:33 AM #2400Natawa ako dito. lol
Pagproblem space but kumpleto ang tunog ang gusto mo, pwede mo try sana 2 6.5" sub ng kicker nasa 3.5k+last ko nakita nakasale sa winterpines dati. Pwede na siya sa ch. 3 and 4 ng amp. Ang enclosure malapad konti sa box ng shoes pwede sa ilalim ng rear seat ng pickup. Gamit ko sa jazz dati ganyan nagsimula sa isa naging 2 6.5" then 1 x 10" DD and now 12" na hehe.
May 6.5" na DD nasa 2k petot o kaya sundown na 1 lang pwede na din.
Tesla Philippines
