Page 244 of 307 FirstFirst ... 144194234240241242243244245246247248254294 ... LastLast
Results 2,431 to 2,440 of 3070
    Aug 2009
    #2431
    Quote Originally Posted by desmosedici View Post
    Thanks for pointing out the existence of these shallow passive subs. Prior that I thought all under seat subs were active. Will consider this especially since ang box requirement niya is only 0.15 to .5 sqf.
    Question lang po, ano advantage ng passive sub like the one you have in your Navarra to something like this:
    Pioneer TSW-X12A Powered Subwoofer | Mickey's Autosound
    Mas effective or madali ba ang tuning if one were using a passive sub?
    If i may chime in, easier to tune ang passive sub than active sub. Since active sub still has "limitations" compared to passive.
    For me also, mas fuller ang sound produced by passive..
    #2432
    Quote Originally Posted by Sleepcare View Post
    Thanks Sleepcare! The good thing is I'm spoiled for choices. Lets see what happens with this install.
    Aug 2009
    #2433
    Please update us with the install. Will look forward for it. Since i'm in the market for Carnival/Odyssey and thinking of audio set-up for it before purchasing.
    Aug 2010
    #2434
    Pa advise lang guys: Will go to Mickey's this Saturday to swap the stock stereo on my 2016 Kia Carnival with these:
    1. New 2-DIN HU (maybe the Pioneer AVH X8850BT because of Car Play)
    2. New 2 way separates (thinking of the Focal P165FX)
    3. An under-seat active sub
    That is the plan as discussed with Mickey but then I found this hardly-used Steg 120.2 Q-mos amp at home from a failed installation about 12 years ago (that's another story). Now I'm wondering if it will do any good to use this amp for the Carnival setup or just save it for another car another day. What do you guys think? Should I use the Steg to power the fronts? Diba overkill ang 120-wpc RMS?
    Note: I'm not open to the idea of a passive subwoofer (heavy and lethal in case of a collision) which is why I'll settle for a small active sub. Thanks in advance.
    Use the STEG to power the fronts. Just remember to have the amplifier checked before installation (Mickey does it for free). No such thing as too much power according to Clarkson nag diba.
    Quote Originally Posted by ParticleX View Post
    Targa pa rin ba bang for the buck? Recently inquired, parang less than 2k lang yung 6 or 6.5in separates nila. Had the X652Cs before, and wala naman akong audiophile ears pero they are good enough. Planning to upgrade another vehicle eh.
    Ano pa ba ibang brands and models available at around 3 to 5k?
    Firland Audio and Ryan Audio comes into mind. Still, why not just stick with Targa. They're OEM suppliers of those Sony/JVC/Pioneer component systems you see in SM you know. Just remember to shy away from raw drivers (you'll notice when they dont have much rubber surrounds) and bullet tweets -- those are LnC gears and in-car listening greatly suffers due to their dispersion characteristics.
    If I would chime in my opinion: same lang sila. Just different ways on how to power a subwoofer. The nice thing about actives is that it already has a power supply built into the casing as well as crossover controls (all in one kung baga) while the passives needs them separately. If you want to be flexible, go for the passive since it's usually the expensive "active subs" that has extensive crossover and tuning functions. For example, you don't really see phase controls on cheap ones.
    But don't underestimate powered subs. Home audio has them aplenty. Pretty sure those Php300,000/pc JL Fantoms aren't active for show.
    #2435
    Thanks for that jhnkvn. Point taken on the passive vs. active subs issue. Will let you guys know how it goes.
    Apr 2017
    #2436
    well sabi nga ni sleepcare and jhnkvn, mas magiging flexible raw sa pag tune ang passive for a cheaper price. And same lang naman daw sila ng output. Bigay lang kasi tong sub na to, my friend bought this 9 yrs ago for 6.7k, tas 2.5k for the box. Sa mickeys nya to binili. May mas mura pa atang version yung pioneer na shallow, yung hindi premier ata hehe di ko sure how much.
    Apr 2010
    #2437
    are Flashbands and alternatives effective in deadening the doors? i sound like a cheapskate as i am one
    any ideas on how much does it cost? also baka may iba pang "generic" siya na pangalan that would help when asking the salesman at the hardware shop
    #2438
    So Mickey's team installed the following on the Carnival:
    Pioneer AVH-8850BT
    Focal ES165K2
    Focal BP20 powered sub (so much for an under seat sub, the presence of under seat rear A/C vents deterred this plan)
    Happy with the fact that no stock wire was spliced, that the reverse cam and steering controls all worked afterwards (tricky that last one), and that the install was so neat - except for the Focal Bomba sub box in the back, everything looked stock.
    The SQ? I think the lively characteristic of Focals is perfect for a car environment. Details rise above the road noise. I love the highs actually - pinpoint and sparkly. Mickey tuned the setup and tonal balance and time alignment is perfect at the driver's seat.
    A bit over-budget but I'm happy to pay for quality stuff, work and results. Thanks to all the tsikot forum advisers.
    Mar 2013
    #2439
    Pioneer AVH-8850BT
    Focal ES165K2
    Congratz. Yes Mickey's is my go to guy. He also did the sounds in my Kia Carnival. But i didnt opt for subs....
    *EQ, where is Mickey's shop? I found out that the sub on the jimny is busted.
audio set-up for beginners [continued]
