Results 1,691 to 1,700 of 3070
- Aug 2015
- 36
August 24th, 2015 08:04 PM #1691Thank you *Egan101. Heard and read reviews of the HUs you mentioned above, hanep ito. Hanep din sa presyo. Thank you for mentioning the DLS, I might revisit decision on the SR5. Bought some of my gears from Mickeys before but I will let Jonz do the buying this time around since I am planning to tap him for the upgrades. I appreciate your inputs, thanks!
- Aug 2015
- 36
August 24th, 2015 08:14 PM #1692Thanks again. Will explore other options - will look as well at secondhand items. With this and the savings coming from the HU, I might be able to get something less the budget I intend to shed.
August 25th, 2015 11:42 AM #1693
Jonz of KAC (Jonz80)? You're in good hands when it comes to car audio. He has truly made a name for himself. If you want an affordable 5-channel amp that's packed with features, go with the DLS CA51. My simple 2-way full active setup before was powered by a CA51. As what jhnkvn mentioned, you get more value with some used equipment so look around as you might find a used DLS A7 for half its retail price.
- Aug 2015
- 1
August 30th, 2015 08:14 AM #1694
- Aug 2015
- 36
September 4th, 2015 08:37 AM #1696
I think most were answered by boss idol master jhnkvn. One thing to take note of is the processor capability of the 6to8. I think it is limited to 24/96. If you plan to play something higher than that, it will just hurt the file.
Your gears are good. Although Audison/Focal are a good match, I think it will be best to invest in tuning instead. Jonz does wonders on it. I was able to make my bright sounding system sound warm to my liking with his expertise.
Also, instead of the amp, maybe change the drivers. I am a big fan of the new Flax drivers from Focal. Really spells out a big difference in tonal quality compared to their older and lower drivers.
- Sep 2015
- 4
September 8th, 2015 12:34 PM #1697For me, unless you hear your trunk resonating, then by all means do deadening. For rear doors, if your rear speakers are disconnected, i find more value in deadening the floor and ceiling since those can be the first point of reflection.
- Aug 2015
- 36
September 8th, 2015 01:40 PM #1698I agree sientobente. Jonz tuned my mosconi and voila, he was able to bring the best out of my current gears.
I have heard some focal audison combos and they are good match. I was contemplating on getting the FX as I have auditioned some before but the sound is not to my liking. I find the midbass manipis compared to the one I have now.
Though I know installation and tuning definitely plays part, I am still unable to audition flax that suits my liking hence the thought of upgrading the amp first. With the amp upgrade, I might be able to squeeze the driver's juices a little bit more. Thereafter I might as well upgrade drivers pag nag sawa na ulit.
Thank you all for your inputs.
September 10th, 2015 02:25 AM #1699
I think that is the default tuning Jonz does, medyo leaning towards manipis, making it sound really clean. Have a listen to mine, I got a focal/audison combo, tuned to a thicker sound. I also have 2 different settings on my processor. It should show you the "Jonz" tune and the "Sientobente" tune. Hahaha. Big difference, pero iba ang clarity on the Jonz tune, while my own tune is midbass strong and thick - as thick as Binay's face!
- Aug 2015
- 2
September 13th, 2015 08:10 PM #1700hi guys newbie here. looking for a good and reliable audio shop in banawe area.
