Results 1,031 to 1,040 of 1411
October 13th, 2020 10:56 AM #1031
2nd floor ng house namin now, cantilevered/overhang all around by 1m, dun sa part na yung mga sanitary pipes ng T&B ng 2nd flr., so if may repairs, nasa labas lang. Pero 22yrs na etong bahay and wala pa naman leaks mga sanitary pipes. May renovation 9yrs ago, pero hindi ginalaw mga sanitary pipes, but replaced all the GI water pipes to Unitec pipes (yung plastic with aluminum).
Signature
- Sep 2010
- 3,006
October 13th, 2020 11:29 AM #1032Another tip too is to keep stock of tiles for incidents like this. Some tiles get phased out or would come in different batches so sometimes iba yung kukay. Otherwise, you’ll be forced to use different tiles, or if you’re OC, you might have to change all your tiles completely para same sila.
October 13th, 2020 11:39 AM #1033
Have not had this nature of failure even on pressurized flush systems. The pressure is built w/in the tank to create more push on each flush....not on the pipes, they are ventilated. Sanitary lines must have good suspension anchors & reliable joints that should withstand vibrations, seismic/traffic/usage or whatever. We commonly see glue & sealants used, but for extreme or OCD applications, ųPVC joint welds are a plus.Good choice on retiring GI supply pipes.[emoji106] PPR has become the more versatile/universal/preferred replacement.
October 13th, 2020 11:45 AM #1036
October 13th, 2020 11:52 AM #1037
Fusion welds are fine & reliable. Thing w/ brands like Rehau & Untitec, their fittings won't likely be compatible w/ other brands of similar system. Should availability be a problem, modding will be the resort. The known PPR brands usually abide by euro-regulations/standards & could be cross-matched. They are the new GI.
October 13th, 2020 11:59 AM #1039
- Sep 2010
- 290
October 13th, 2020 09:03 PM #1040Anyone tried laminated flooring? Upon searching, ang cons na nabasa ko is bawal mabasa dahil magiging "weak" yung material. Also, may specified cleaner ba to clean laminated flooring since hindi pwede i-mop?
TIA!
Tesla Philippines
