Page 134 of 142 FirstFirst ... 3484124130131132133134135136137138 ... LastLast
Results 1,331 to 1,340 of 1411
    #1331
    You see the exterior walls of most malls(all SMs)? EIFS....search for a specialist local to you, sir.
    So I would search for EIFS specialist? Thanks for the tip sir.
    #1332
    Parex/La Habra, Pleko, Dryvit are some of the brands you can search. Dryvit used to be carried by Republic Chem(Pioneer Epoxy) decades ago, but I guess they no longer are. I'm just not sure who the specialists are local to you. Homegrown Island Paints also has a vertically developed division. Even the fire-rated polystyrene insulation core comes from their in-house subsidiary.
    Jan 2016
    #1333
    Can anyone make a suggestion? Yung 2nd floor namin is concrete slab yung roof at wall. Now one side of the wall and the roof is absorbing too much heat during day time. Ang resulta mainit sa 2nd floor. I can really feel the temp changing pag umakyat na ko. I thought of putting an air condition on the rooms but it may be half as efficient kung ganito kainit.
    We are planning to put a lot 3rd floor this may shield the 2nd floor roof from heat, yung wall na lang ang problem on what we can do so it wouldn't absorb heat so much.
    Also the 3rd floor roof, what can we do so it wouldn't absorb heat too and end up with same problem.
    Problem ko din ito dati, I thought of putting a double wall or a styrofoam enclosed by a drywall. kaya lang ayoko na maabala ng trabaho inside the house, so i did not push through, but this may help.
    #1334
    Put solar panels on top of the roof!
    #1335
    Can you plant trees that will somehow block the sun from your wall?
    Signature
    #1336
    The advantage of EIFS is that it's ideally externally laid, preventing heat retention on the existing concrete wall. Doing it from the inside won't be as effective. Plus, the stucco epidermis will be more durable than paint.
    Jun 2011
    #1337
    Puwede external aluminum fixed blinds na facade gaya nito.
    Click image for larger version.
    Aluminium sun shades - merlo
    Aluminum sasalo ng sunlight/tapos external air cooling.
    Puwede siguro pa sadya sa aluminum shop, tapos per panel install. Gawing typhoon proof.
    Maganda malayo allowance sa wall para sa air cooling.
    Jun 2011
    #1338
    Puwede din external bamboo blinds.
    Madalas nga lang sa balcony.
    Kailangan i roll up kung may bagyo.
    Edit: okay din pala bamboo cladding.
    bamboo clad office building in france by monica donati
Name:	Screenshot_20210330-143310_Samsung Internet.jpg
    Puwede kung walang space sa trees na suggestion ay green wall.
    Kailangan nga lang maintenance access.
    Green facades | Urban green-blue grids
    #1339
    Taniman ang perimeter fence ng Japanese bamboo, abot shade nyan sa 2/F.
    #1340
    One of the best pa in absorbing carbon dioxide yang bamboo plant.
House Constuction [Merged]
