Results 41 to 50 of 902
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 18th, 2006 09:37 PM #41ok yan. just don't forget to turn off and unplug your generator before switching on the breaker. PAgnagsalubong ang kuryente.......:boom1:
October 18th, 2006 09:50 PM #42
make sure naka switch OFF ang circuit breaker nyo
pwede din iyan ang hassle niyan ang mag tap ka sa Load Side ng CB ninyo every time may Brownout
! may kuryente na kami na kami (electric fan nga lang, aircon at tv, sa ilaw, lamp lang na de saksak, hiwalay kasi linya ng ilaw sa saksakan eh)
ang mga Lighting Outlet (LO) sa mga Convenience Outlet (CO)
kaya minsan kung may nagshort circuit sa mga CO ninyo at nag trip ang breaker non ,may ilaw pa din sa bahay or room ninyo
same ng mga Water Heater,ACU may kanya kanya sila breakerLast edited by BoEinG_747; October 19th, 2006 at 05:16 AM.
- 2,719
October 18th, 2006 09:51 PM #43
October 18th, 2006 10:04 PM #44
Actually, okay lang dapat iyan kung isasaksak mo ang output ng genset sa isang outlet na may 30A na breaker, which I assume has wiring capable of accomodating 30A. Kasi 30A x 220V = 6600VA or 6.6KVA,- meaning huwag lang tataas ang genset mo sa ganyang power output.
And most importantly, turn-off the main breaker. If not, then the genset will be acting like a load (i.e. a motor) when regular power returns. Iyan ang delikado!
:starwars:Last edited by CVT; October 18th, 2006 at 10:21 PM.
October 18th, 2006 10:08 PM #46
what i did naman is i installed a panel intended for use lang talaga with the generator, tapos after load balancing from that panel, distribute the supply to the load side of the main panel ng bahay, wherein i pick only those appliances that i really need to run during power failure... like water pumps, refrige, some aircon, selected convenient outlets and lightings. then yung remaining, still connected pa rin sa MERALCO, in that way, pwedeng simultaneous ang paggamit ko ng power from both MERALCO & generator, just want to observe lang if makakatipid ako sa power cost since consumption ko with MERALCO will be reduced... actually i just started today doing this kind of setup, still i need time pa to determine if makakatipid nga talaga.
October 18th, 2006 10:15 PM #47
- 2,719
October 18th, 2006 10:30 PM #48hindi po kayo makakatipid sir driven ... gamitin nyo lang ang genset kapag walang kuryente sa meralco para hindi sayang ang pera
you could be spending as much as 10 times the meralco rate for the energy coming from the genset ... but i'm not stopping you doing your experiment and tell us your findings... the figure i've given is what i vaguely remember when we used our genset (6.5kVA Honda) long time ago
Tsikot Member Rank 5
- 3,144
October 18th, 2006 11:28 PM #49
October 19th, 2006 07:04 AM #50
may point din kayo sir kinyo, actually i was able to check the specification of our gen set, since ang fuel consumption ng engine at 50% load is 3 li/hr, if i know the power rate from MERALCO, i might be able to come up with a figure that can better visualize the comparison... thanks
Tesla Philippines
