Page 15 of 145 FirstFirst ... 51112131415161718192565115 ... LastLast
Results 141 to 150 of 1445
    #141
    Quote Originally Posted by s_quilicot View Post
    pa check mo na sa casa yan or check the fuse box first.
    (gamitin mo rin naman daw kasi trooper mo!!!)
    ginagamit ko naman eh..
    malapit na sya mag 135k PMS
    #142
    yung Trooper ko ayaw mawala nung ABS warning light. :shocked2: ano kaya problem?
    Just had that problem recently. What I did clean the wheel sensors and everything went fine. Sana yun lang problem mo.
    #143
    Quote Originally Posted by 4JGtootsie View Post
    s
    should i post my trooper's brake problem?
    guys, dont you find the troopers ABS to over reacting? yung tipong sobrang hina na ng brake kahit makapit naman yung ground?
    #144
    anong sensors bro?
    #145
    anong sensors bro?
    Wheel speed sensor. Its mounted on each wheel at the back of the rotor.
    Its magnetic therefore iron fillings sticks to it.
    SQ,
    I have experienced a trooper with and without an ABS. Maninibago ka talaga dahil parang mahina/spongy ang brakes pero thats how antilock brake system on trooper works. Ang laki ng rotor ng front and rear brakes ng mga trooper malabo mag fade yan unless controlled ng ABS.
    Aug 2007
    #146
    reply to 4wd indicator lamp being on even if the 4wd is not engaged...
    hello, try checking the solenoid switch at the front axle, it's located the middle of the front axle and it's covered by a metal shroud. there's 2 vacuum hoses connected to it. either one of the hoses were disconnected or the wiring is faulty or the vsv switch itself is faulty. i own a 96 isuzu MU 4wd, it shares the same front under chassis of your bighorn. had the same problem once, fortunately, one of the hoses were disconnected when i installed a steering damper.
    #147
    4JGt, siguro kailangan ko na palinis yung brakes ko. pero check ko later yung fuse.
    SQ, yung sa akin kahit may warning ganun parin ang brakes. siguro activated parin ang ABS
    #148
    [QUOTE=Starex_Gold;1256690]4JGt, siguro kailangan ko na palinis yung brakes ko. pero check ko later yung fuse.
    No need to clean brakes, caliper disc brakes are very low maintenance. Best you can do is drain all brake fluid and raplace with new. The wheel sensors can be removed by a bolt with allen wrenchm then twist it side side pulling out slight until lumabas na siya. Masikip siya kaya tyaga lang. Sa likod size 12 bolt naman. Clean it with tooth brush and/or spray with contact cleaner.
    SQ do this also, wheel speed sensors plays a vital role in determining if you have lock up. If it cant read (because dirty) the speed it can light up the ABS warning light.
    #149
    [quote=4JGtootsie;1256793]
    Ive replaced all the fluids na. new pads narin
    anong pads pala gamit nyo?
    #150
    Quote Originally Posted by jango View Post
    Hello,
    I want to restore our old trooper back to good condition. its a 97 3.1 diesel m/t model.
    can anyone point me to the right direction on what i need to check/replace?
    oil
    oil filter
    fuel filter
    coolant
    tranny fluid
    brake fluid
    p/s fluid
    anything else? btw what we always do is just to blow the air filter with compressed air every now and then.
    ganon ba talaga yung old diesel trooper? makalog at maingay?
    thanks
    anyone?
Isuzu Trooper discussion
