Page 19 of 145 FirstFirst ... 91516171819202122232969119 ... LastLast
Results 181 to 190 of 1445
    Feb 2005
    #181
    Quote Originally Posted by s_quilicot View Post
    pero may new problem, may bluish white smoke na mejo malakas.
    Hmmm, is this continuous or only when coming from a long, standing idle?
    #182
    Quote Originally Posted by Benzmizer View Post
    Weird. Minsan malakas, minsan mahina. Minsan kapag naka idle lang, minsan continous. Pinapalitan ko ng O-ring kagabi malaking improvement (scandalous kasi before) pero may konting usok parin.
    Have you expirienced this bob?
    May 2004
    #183
    oh oh. did you do a compression test sq after you install the new head? ano sabi mechanic mo?
    Feb 2005
    #184
    I always do BUT when the vehcile has been idle for a couple of minutes. This produces that weird stinky smell. It's caused by the special motor oil we put (BESCO) But after continuous acceleration from idle, it disappears.
    Quote Originally Posted by niwde11 View Post
    This I also recommend IF the bluish white smoke does not disappear even after the vehicle has accelerated. As in tuloy-tuloy at di nawawala. lalo na kung nagpalit ka ng head. Did you have your Trooper undergo Tech 2 check after the engine fix?
    #185
    not yet niwds. first thing we do was to replace the injector O-rings with a new one. Dramatic effect felt.
    Before kasi scandalous talaga. As in parang naka smoke dispenser na security accessory ng armored car.
    I remember that during my BESCO days but now its kinda stange. Minsan malakas, minsan mahina at minsan contionous. Also the oil pressure drops sometimes to almost Zero. Parang nag fa-flactuate.
    Nest move is to check valve clearance daw.
    May 2004
    #186
    yeah check valve clearance(and stems *not sure with the term*). bluish smoke is a sign na sumusunog ng oil.
    #187
    next week after exams
    So far hindi naman nagbabawas ng oil. haaaaaaaaaay.
    niwds, anong size ng gulong mo right now?
    May 2004
    #188
    265/75R16 lang
    #189
    may rubbing?
    May 2004
    #190
    none. according to some experts pag 285/75 ang me slight rubbing. pero dami pa rin gamit ng ganung size.
Isuzu Trooper discussion
