Results 131 to 140 of 1445
- Nov 2010
- 236
September 30th, 2013 02:29 PM #1
September 30th, 2013 02:57 PM #2
My Trooper underwent 2 complete injector replacement -- which included RPS, RPCV and TPS relays (these conidered to be maintenance items and may be replaced in the future -- of course, on the account of the owner
Based on my experience, there were variable symptoms depending on the suggestive extent to replace 1 or 2 or 3 or all 4 injectors (note that injector can be replaced individually and not necessarily altogether). Some I notice were the erratic idling (you see the RPM needle play), power lose (some consider limp mode), hard starting (which should not be overdone or the starter may get damaged and battery be drained/damaged) to name a few.
But there is no best way to confirm what the problem may be without the Tech 2 gadget. That way, the Isuzu-trained technician would be able to pinpoint the culprit.
- Nov 2010
- 236
October 2nd, 2013 02:34 PM #3Sad to hear that sir but still.do no pa binebenta trooper mo...un as amin till now fingers cross sana do muna bumigay injector(pinalit nung recall) and tps...nagpalit na ako ng rps rpcv once palang...timing belt nagpalit na nung 160+++km but not the tensioner....
Sir pa OT yung remote ng alarm may Alam kabang makukuhanan? Or kahit yun shell lang Order basis as inteco pampanga Pero mukhang walang dumarating....TIA
- Apr 2013
- 5
October 3rd, 2013 12:41 PM #4Just want to share my bad experience with Isuzu Makati! Last Aug. 24 I went there to have my trooper checked using tech 2 and by the technician. Nagbabawas kse radiator coolant every now and then. Iniwan ko sya sabi kse ng tech na nakausap ko (Arnel ata name nya) balikan ko na lang dw mga around 4 pero tatawagan nya muna ako. Then naghintay ako ng tawag nya nung hapon kse ayw kong iwanan yung trooper dun ng matagal since saturday yun tapos sa monday holiday. Nung nakausap ko sya, sabi ok naman daw trooper. Normal lang daw mga gsto ko ipacheck. E di pinuntahan ko na. Nung dumating ako, ala na sya nakaalis na daw pero binayaran ko rin yung 990 pesos para sa tech 2 and yung inspection fee. Then nung nabayaran ko na, hinanap ko yung print out ng result ng tech 2 para maitago ko for reference sa future. Ang sabi nung isa, ala daw iniwan sa kanya si Arnel tawag na lang daw ako sa tuesday. Nung tumawag ako nung tuesday, ala daw print out kse ok naman daw. Ang sabi ko, dapat meron yun kahit may problema or wala yung trooper. Tapos dun na sya umamin na hndi daw na tech 2 yung trooper kse linabas daw sa casa yung machine!
Sobrang hassle ginawa nila. Gusto nila ibalik ko daw uli sa knila yung trooper para i tech 2 for free! Ngayon, mahirap na talaga magtiwala kahit sa Casa!
October 6th, 2013 01:54 AM #5
ako din,ng pinatech2 ko trooper ko sabi ko kuhanan ng reading ng before & after....pero di ginawa ni Arnel. ng natapos na. buti na lang na picturan ko yung mga initial reading, pinasok ko sila sa loob ng maintenance bay nung ginagawa pa.
hindi rin nagsasabi yan kung may nasira sila. ni recommend ni Arnel na palitan ko yung radiator hoses. nung pinalitan nasira yung radiator outlet kaya nagpalit na ako ng radiator top cover. buti nalang nakita namin pag dating sa bahay na tumatagas na ang coolant....
- Sep 2013
- 4
October 3rd, 2013 05:56 PM #6Dinala namin s kasa tapos inasses nila, ewan ko lang kung accurate assesment nila, pero siguro tama naman. Ang suggestion nila is replace fuel injectos, along with other work p daw.
- Sep 2013
- 4
October 3rd, 2013 06:06 PM #7Inasses kase nang Isuzu Alabang yung Trooper at ang sabe nila sa Job Order n kelangn palitan nang Fuel Injectors along nang iba pa na papalitan.
Bago masira malakas ung smoke n nilalabas pte itim n itim. Hnd n namin pinilit i andar, dinerecho n namin s Isuzu. Yun nga lang ang mahal talaga nang mag pagawa sa Casa
October 6th, 2013 01:57 AM #8
jdyboy,
kamusta trooper mo? ilan days sa casa? ilang injector ang pinalitan? magkano inabot?
- Oct 2013
- 1
Tesla Philippines
