Results 331 to 340 of 386
November 26th, 2018 06:54 PM #331
Mga sir patulong naman po. Minsan namamatayan ako ng engine hindi ko talaga malaman ano problem. AT 2011 S variant. Nasa drive naman tapos bigla nalang namamatay engine. Ano po ba ang solution for this? TIA
November 26th, 2018 07:03 PM #332
November 27th, 2018 10:33 AM #334
November 27th, 2018 11:11 AM #335
If you bring it to a Ford dealer and upon checking the error/fault is related to TCM, they will not charge you anything. Ford cars with the dry-clutch DCT has an extended warranty for its TCM (240k kilometers or 10 years).
You can buy your own OBD scanner to check the error/fault codes but if you don't have the data to cross-reference code with the actual error/fault description, you will still have to consult a Ford dealer or download online data if you can.
November 27th, 2018 11:28 AM #336
November 29th, 2018 09:20 AM #337
- Nov 2018
- 6
December 9th, 2018 02:09 AM #338Mga sir ptulong nmn po, nkbli po aq ng fofi 2014 s variant hatchback, npansin q po n hindi gumagana ung highbeam nya, nung tningnn q ung fuse at relay n notice q n wla xang relay base s owners manual, R4 po ung relay ng highbeam, tpos base dn s owners manual ung R5 eh not use, gzto q po sana ilipat ung relay ng R5 to R4 pra s highbeam, ok lng po b un at wla po bng mgiging problema?thanks in advance
December 9th, 2018 02:24 AM #339
bro shorthand is kinda difficult to read and its prohibited. I didnt even bother reading the rest of your post😅
- Jan 2008
- 4,726
December 9th, 2018 02:44 AM #340
Tesla Philippines
