Results 231 to 240 of 386
- May 2016
- 15
May 21st, 2016 11:55 AM #231
June 4th, 2016 02:58 AM #232
*Sir Egan Its hard for me to find the recommended viscosity for Fiesta 5W-20 / 5w30. I had to use 5W-40 since yun lang available btw hindi ko na pala sa casa pinapaservice si Fiesta. Tiwala lang ako sa trusted service center ko. Okay lang kaya na 5w40 nagamit ko? Kaya ngayon in a hunt na ako for a receommended oil for Fiesta kase laging wala.
June 4th, 2016 03:28 AM #233
Zic x7 fs 5w30 dexos1 - this will exceed requirements by ford. No need to look for motorcraft oils. Hehehe
ZIC X7 5w3 Fully Synthetic Gasoline Engine Oil 4L (8am-1 pm | *******
June 6th, 2016 10:21 AM #235
Ford Manila Bay uses Shell Helix Ultra 5w30 oil for my Fiesta. No problems with it ever since.
If you really want to use Motorcraft 5w20 or 5w30 motor oils, FordMaz in BF Homes have them available. The 5w20 oil is a bit more expensive than the 5w30 oil. Try giving them a call if you want to stick with Motorcraft oils. After my warranty period, I plan to do my change oil services there. I went there when I had my front brake pads replaced.
June 8th, 2016 07:18 AM #236
June 8th, 2016 07:42 AM #237
Just look at the label of the oil and make sure they meet the following standards.
SAE - 5w20 or 5w30
ACEA - A5/B5 or A3/B4
API - SN
By the way, have you changed spark plugs already? This small potent engine uses a specific type of spark plug and it is 1500 per piece locally unless you source it in Europe or the US. See below:
NGK SILZNAR8C7H
Motorcraft/Ford 1770305
- Aug 2016
- 26
August 18th, 2016 04:53 PM #239hi guys..
is the 2016 Fod Fiesta hatchback still has the same issue na may kumakalmpag sa baba?
August 18th, 2016 05:06 PM #240
What do you mean by "kumakalampag sa baha"? Most people complain about the clankiness of the Fiesta's transmission but it is more of the nature of the dual-clutch tranny which most people locally are not used to.
Besides, who in their right mind will ever be brave enough to plow thru high water their cars? Kung iilang inches of water lang yan, kaya naman. Pero kung tuhod na yung tubig or sa waist, think twice or not dare at all.
Tesla Philippines
