Page 37 of 39 FirstFirst ... 2733343536373839 LastLast
Results 361 to 370 of 386
    Nov 2017
    #361
    Quote Originally Posted by masakitsaulo View Post
    Trend 1.5 HB sir...nag text ulit ang dealer at ngayon ay nasa 80k daw ang total cost of repair.. hindi na daw sakop ng warranty kasi 5.3yrs na daw ang fofi ko. same problem pa din na di nila nagawa at nadagdag pa ngayon na papalitan ang shift fork bukod sa Clutch assembly na pangalawa na.
    Can you get the list of parts that they're going to repair/replace, and the cost for each? Are these the same stuff that was repaired previously?
    Jan 2012
    #362
    It should be covered by the extended warranty. Alam ko Ecoboost models lang ang hindi covered ng extended warranty for clutch assy. Let them check your VIN to verify.
    #363
    Quote Originally Posted by carwhacko View Post
    The Ecoboost models are also covered in the tranny extended warranty. I received a letter indicating so.
    Jan 2012
    #364
    For the clutch assembly hindi. I had mine checked last year.
    Apr 2019
    #365
    Clutch assembly P40,300 (was replaced on March2017 under warranty) + Shift fork P27,200 (new repair) + P2100 diagnose fee + P10,000 transmission remove/install. I have to pay P20,000 advance for them to start the repair.
    Nov 2017
    #366
    Woah, these are expensive repairs for just a small car like the fiesta!
    Have you tried other ford branches just to verify if they'll see the same issues? How about other car repair centers like Drive+ Car Care if in case your car is already out of warranty?
    Apr 2019
    #367
    yes napakamahal talaga..hindi ko alam kung pwede ko pa ilipat sa ibang ford branch kasi baklas na transmission. ang inaasahan ko lang ay ang clutch assembly na masakop ng extended warranty at discount para sa ibang parts at labor charge.. more than 1 month na po sa kasa pero di pa nila ma confirm ang warranty extension nung previous repair sa clutch at ang hinihingi kong discount.
    Apr 2019
    #368
    Update sa naging issue sa fofi ko matapos ang higit 3 buwang pag-aantay, pangungulit at pakikipagtalo. Palit ng clutch assembly, TCM, fork, transmission harness at 2 trans. actuator motor lahat ay free of charge pati labor. Thanks Ford
    Nov 2017
    #369
    Ford is going down the drain...
    https://www.carguide .ph/2019/07/ford-could-face-largest-lawsuit-against.html
    Fields is set to testify in a series of cases involving customers who opted out of the class-action lawsuit that complained about Ford’s problematic dual clutch transmission and its propensity to shudder, jerk, and hesitate. The suits have since been combined into a federal case in California where Fields has been ordered to appear in court by July 31.
    At the time the dual clutch transmission was introduced, Fields was Ford’s president of the Americas and his disposition is critical in confirming that Ford’s executives at the highest level knew of the problems with the transmissions, intentionally concealed that information, and sold the vehicles to the public anyway.
    If Fields confirms that he has knowledge that the company intentionally hid the PowerShift problem, they could face the largest lawsuit against the problematic gearbox and could be hit with a potential USD 4 billion (~ P 208 billion) liability.
    Jun 2013
    #370
    Didn’t their mothers teach them not to lie? Lying will only get them in trouble. 😂
Ford Fiesta Issues
