Page 259 of 390 FirstFirst ... 159209249255256257258259260261262263269309359 ... LastLast
Results 2,581 to 2,590 of 3899
    #2581
    Quote Originally Posted by lolo pepe View Post
    Starex D4CB crdi has the same filter thread size as that of Mitsu 4D56, 4m40 and 4M41 which is M26 X 1.5. So Baldwin BD28 (combo filter) is compatible. The Hyundai OEM filter is only full flow so BD28 (full flow + bypass) is one step better in oil filtration.
    Since BD28 is hard to find, I use Bosch OM 084 and change it every 5K km since the efficiency rating is not available (just to be safe). However, I change my oil (Caltex Delo Gold Ultra 15W-40) every 10K km.
    CMIIW, but both Starex crdi (non-vgt) and crdi vgt share the same D4CB engine configuration so they have the same thread filter size. They only differ in the turbo design.
    Hope this helps.
    Thanks lolo pepe, I guess a full flow filter with the same thread specs will do for the GS. I wonder which one in Fleetguard or baldwin has the same thread size ... ? hmmmm
    Aug 2006
    #2582
    Baldwin B7014 and B7045 as well as Fleetguard LF3689 are full flow oil filters that have the same thread size. (Reference: Sir Ry_Tower's post #2556.)
    #2583
    Salamat sir...
    Aug 2006
    #2584
    no problem, sir.
    #2585
    LF3830 is also full flow but a bit bigger than BD28/LF3564.
    #2586
    Hope this helps.
    Yari, kaagaw na naman sa stocks ng BD28 mga naka-starex. hehe
    j/k lang po. More reason for volmax et al to stock-up on BD28's/BD7028 then.
    #2587
    ^^^Matagal na kayang kaagaw sir...Starex din ride ko eh
    #2588
    Quote Originally Posted by mateomarco View Post
    haha, kaya pala nag-hoard ka na rin ha. hehehe
    Jan 2012
    #2589
    sino punta volmax soon?
    pakisuyo naman mga sirs B1402, - may stock daw 350 each. hehehe
    #2590
    Thanks po sa replies so BD28 pala for Starex (H1) Gen 1-3, Crdi and Grand Starex. Tama ba mga sirs? Yung Bosch OM 084 available ba ito sa Warren sa Binondo & how much po?
Remote bypass oil filtration
