Page 269 of 390 FirstFirst ... 169219259265266267268269270271272273279319369 ... LastLast
Results 2,681 to 2,690 of 3899
    Dec 2007
    #2681
    Your fuel economy will suffer with 50 weight oil and it has no advantages with daily driving, i am not a fan of mixing oils if you dont know how the additive package will be boosted or watered down.
    I would check the spec sheet first. But if you got the 50 weight alread.
    Also thats not how mixing different weights works thet use different viscosity modifiers whicch may act in a way u dont expect. No it wont hurt your motor but i am not a big fan of that.
    May 2012
    #2682
    At 4000km reading, castrol magnatec with the famous vic oil filter, i can already feel the sandy feeling of the oil using the tissue test. But the oil color is still ok.
    On my next oil change, i will be using zic up oil and the valvoline oil filter i got from doc.
    Feb 2007
    #2683
    Finally got my filters from dlvdoc yesterday. Ambibigat pala ng mga filter nato. Thanks doc :2thumbsup:
    Dec 2007
    #2684
    I will be going back to the states in a few weeks so get them while the getting is good.
    Feb 2007
    #2685
    gonna order this week filters for innova and diesel accent after i've changed oil the van and will take a pic of the secondary filter/water separator if you have one on stock.
    #2686
    A bit OT. I got my Caltex Delo Gold Ultra for P1190/5L. Wala silang 4L or 1L lang eh. May less P100 discount sila so P1090 na lang hehe. Di ko lang alam kung all branches pero new oil pala nila yun. May pin pa yung mga gas boy na nakakabit sa damit nila about their Delo Gold Ultra.
    #2687
    Quote Originally Posted by robed4 View Post
    Read few articles on the net that it is safe to mix oil weights as long as both are of same category. So as not to waste
    my in-stock TOP 1 5w/50 FS, I would like to mix it with a ZIC A+ 5w/30 FS with the following ratio:
    1. For a 4L-oil capacity gas engine:
    Top 1 : 2L
    ZIC A+ : 2L
    will result to Brand X 5w/40
    2. For a 6L-oil capacity gas engine
    Top 1 : 3L
    Zic A+ : 3L
    will also result to Brand X 5w/40
    You thoughts please .......... thanks.
    If while on the road you are forced to add oil there are rules. Let us say for example that our engine has synthetic Mobil One 0W-30. Use the same type and brand if you can. If you are using Mobil 1 then it is acceptable to mix different grades but use a close grade when possible. It is not a good idea to mix say 1/2 your oil tank with 0W-30 and 1/2 with 15W-50 Mobil 1. If there is no Mobil 1 available then use the mineral based Mobil oils next.
    The last choice is to mix a synthetic of another brand. They should not react adversely if mixed but it may dilute additives. This is not a good combination. Use this combination if you must but only until an oil change can safely be performed some time soon.
    #2688
    Selected gas staions lang bro. Dito sa amin nga 2 lang meron niyan. 5L pack nga DGU pati Delo 400. Yung DG ang 4ltr.
    #2689
    how much delo 400 dyan RT?
  10. #2690
    Reasonable na ba ang Delo 400 at P260 per liter? Yung malapit sa amin, P170 si Delo Gold and P220 si Delo Gold ultra.
    Gotta head back to Volmax soon for some BT223's and a couple of B2's. Hoarding time!
Remote bypass oil filtration
