Results 171 to 180 of 6552
May 11th, 2012 09:11 AM #171
May 11th, 2012 10:59 PM #172
- Jan 2008
- 172
May 12th, 2012 04:26 AM #173^currently using Elf Excellium SM + baldwin oil filter on my gf's 08 Altis.
here's a link of its specs and reviews:
ELF EXCELLIUM SM 5W40 2010 - Singapore Motor Guide
so far so good. at 550php /liter, mas mura to compared sa motul (640?), mobil1 (800+) at valvoline Synpower (700+/-).Last edited by Errol5; May 12th, 2012 at 04:27 AM. Reason: additional input
May 12th, 2012 10:33 AM #174
Delo Gold Ultra/Mobil delvac Mx or any diesel oil with API CI-4 and SL rating. Yan ang maganda for extended oil drain itervals eh. Again balikan yung manual ng ride mo if designated na API SM/SN dapat. Yun kasi yung kelangan if may catalytic converter ride mo eh. Bawal dun yung mataas zinc which is marami yung mga API SJ/SL oils most of the time. But if manual recommends SL rating, IMO the best pa din mga diesel oils even for gasoline engine. Nakalagay din naman sa bottle nila yun eh.
Fasten your seatbelt! Or else...Driven To Thrill!
May 12th, 2012 12:41 PM #175
May 12th, 2012 12:48 PM #176
mas robust ang mga diesel rated engine oils at maganda kasi additives package....
May 12th, 2012 12:57 PM #177
For modern CRDi engines specifically for those korean SUV's which is powered by R-eVGT engine, will the Delo Gold Ultra/Mobil Delvac MX or any API CI-4 rated diesel oil work on that type of engine? o kailangan talaga ung mga fully synthetic oil like Mobil 1 or RP. I have read in other threads na dapat synthetic oil ang gamitin with that particular type of engine. Kindly advised. Thanks.
May 12th, 2012 03:36 PM #178
its not actually a question sir retz of whether its fully or semi synthetic or mineral... i think the advised made by HARI on insisting that user owners and casa must use FS oil, is base on the emission devices that came with their models , the Selective Catalytic reduction devices and their diesel particulate filters together with prolonging oxygen sensor...
which needs low Phosphorus and zinc (SAPS)
kung hindi kasi issue ang mga emission devices na toh... Delo Gold and Delvac and other strong diesel lubricants will offer much longer protection...
kaso need nang casa na i-prioritize na ma-prolong life nang mga emission device,,
most Fully synthetic oils are CJ-4 rated na.... meh limit na sa ZINC and Phosphorus...
- Jan 2008
- 172
- Apr 2011
- 78
May 12th, 2012 09:31 PM #180[QUOTE=Errol5;1926065]^Mobil TDT pa lang yata nakita ko na Cj-4[/QUOTE
try mo tingnan sa ACEhardware yung MAG 1 All Fleet SAE 10w30 at saka SAE15w40 engine oil its rated as API CJ-4/SL,SJ.
it cost around 1300+
Tesla Philippines
