Page 8 of 656 FirstFirst ... 4567891011121858108 ... LastLast
Results 71 to 80 of 6552
    Oct 2004
    #71
    Sir, pwede paki indicate na rin ung API rating ng ZIC oil above para malaman kung pwede sa gasoline/diesel or pang diesel lang ba ito. Thanks po.
    More info at this link:
    SK ZIC
    #72
    Used it last time on my FD, Meron ako voucher Sa true value..same, same....
    May 2009
    #73
    I'll be using Delo 400 on my next oil change. Delo 400 is P295/liter at my place. About P1.4 - 1.5k per 5 liter jug. The label itself have no claims of it being a synth or a semi so i concluded it's a regular dino (w/ chevron's so-called ISOSYN tech). it also claims that it is at par with prevailing other synthetics' performance. we'll see. TBN as per the internet is 12.6. am not sure with the ZDDP. but i suspect it has still considerably high amounts of it.
    Yung Mobil TDT na nakita ko sa mall eh P600 plus per liter dito....Delo 400 na lang kung ganun.
    Dec 2009
    #74
    delo 400 is a very very good oil...
    Oct 2011
    #75
    I see some poster mentioning the Shell Helix HX5. Upon looking at its API rating it is rated API SL/CF which I think is more suitable for gasoline engine whereas Shell Rimula R3 is rated API CI-4 which is designed for diesel engine.
    #76
    ^ API CI-4 na ba Shell R3? Afaiak CH-4 lang. Anyway it's a good oil naman.
    #77
    So which is more suitable for both the 4JA1 NA and turbocharged powerplant? Shell Helix diesel HX3 or the Shell Rimula R3?
    #78
    it would really depend on your budget. and yan lang ba option mo sir? or open kayo sa ibang options?
    Oct 2011
    #79
    Yes, If my recollection is correct yan ung nabasa ko sa front label. I think it is around Php230 or 250/Li. Mas mahal ng konti ung Helix HX5.
    #80
    No question sa budget. I'm asking about the suitability between the 2 choices of Shell engine oils.
    Or I can paraphrase my question...Is there a real advantage if I use HX5 instead of Rimula R3 for old school diesel engines?
Mineral , semi synthetic or fully synthetic?
