Results 941 to 950 of 2348
April 12th, 2010 04:22 PM #941
Sir Dieseldude,
I have suggested to my uncle that he brings his Super Grandia to your shop in Q.Ave. You also fix Denso right? (D-4D)?
The problem, as diagnosed by Toyota (though it's strange), is that one of the injectors is not working. However, the car is working fine, it doesn't shake, it has the same power as before. Toyota alleges that the Check Engine warning indicates that one of the injectors is malfunctioning but i have talked to another diesel mechanic friend of mine and he said if one of the injectors has indeed failed, it will wiggle and shake wildly. He suggested I have it checked (pressure check or something like that) so I thought of having it brought to your shop. Is this correct?
Thanks a lot.Last edited by Horsepower; April 12th, 2010 at 04:35 PM.
- Sep 2006
- 1,335
April 13th, 2010 08:29 AM #942Hi Sir Dieseldude. Itanong ko lang yhe easiest way to tell if the turbo of a 4d56 engine is functioning. kasi parang hindi hindi sya gumagana especially kapg na hit nya 2000 rpm. I have a montero kasi. when i accelerate and the rpm touches the 2000 mark, madidinig mo and feel the response of the engine. Measure boost with a boost gauge if you have one. Another way (but not accurate) is: rev up the engine, and look/feel the hose to the intake manifold for pressure. As you rev up, this hose will expand and become rigid if the turbo is building pressure..
Hope you can help. Thanks in advance.
PS.
May alam po ba kayo tungkol sa rotrex supercharger? Sorry, never heard of this product.
TIA
- Sep 2006
- 1,335
April 13th, 2010 09:29 AM #943Sir Dieseldude,
I have suggested to my uncle that he brings his Super Grandia to your shop in Q.Ave. You also fix Denso right? (D-4D)? Yes..
The problem, as diagnosed by Toyota (though it's strange), is that one of the injectors is not working. The supposedly "not-working" injector is still working. But its fuelling contribution may not be the same as the three injectors'. This can be seen with a scan tool.
However, the car is working fine, it doesn't shake, it has the same power as before. Good.
Toyota alleges that the Check Engine warning indicates that one of the injectors is malfunctioning but I have talked to another diesel mechanic friend of mine and he said that if one of the injectors has indeed failed, it will wiggle and shake wildly. This is true if the injector has totally failed (no fuel delivery). However, a malfunctioning or partly failed injector may still be contributing fuel, and not be noticed because the engine seems to be performing normally.
He suggested I have it checked (pressure check or something like that) so I thought of having it brought to your shop. Is this correct? We can check it...
Did Toyota specifically say that the CEL was due to a faulty injector? What cylinder? What was the fault code?
Thanks a lot. You're welcome.
April 13th, 2010 01:32 PM #944
Sir Dieseldude may I get the address of your shop in Q. Ave?
My problem is other people who drive my car complain of the lack of power when pushing from 60kmph up, as in when trying to overtake. From 60 to 80 and higher it fails to accelerate quickly. However when done in a slow manner (acceleration over a longer period of time, say more than 1 minute) it does fine. I am a slow driver so I do not experience what they complain about.
It's 2nd hand (3rd hand? maybe more) and it is a converted RHD-LHD automatic vehicle (subic most probably) Toyota Hilux Surf 2.4 EFI turbo diesel. I like it so I am treating it like a project car (meaning it is costing me too much. LOL!). TIA.Last edited by OldSchoolHack; April 13th, 2010 at 01:34 PM.
April 16th, 2010 12:05 PM #945
Sir dieseldude,
what kind of oil (grade & brand also if possible) must be used on a injection pump/governor assembly? is it engine oil, gear, atf, cooking( hehe), etc?
thanks a lot.
- Sep 2006
- 1,335
April 16th, 2010 05:25 PM #946
- Dec 2008
- 22
April 18th, 2010 10:45 AM #947sir, may i know the address of your shop,,,contact number? I'll bring my 2003 pajero fm. salamat
- Sep 2006
- 1,335
May 2nd, 2010 07:12 PM #949
sir dieseldude
good day po.. newbie here.. pasensya na po bout sa mga common sense na questions ko, pero curious lang po ako kung kelangan ko na po ba icalibrate yung 4d56 engine sa adventure, since it's already have a 105k mileage. 7 years na din po sa min ung sasakyan, and every 5k kms eh change oil sya. every 10k kms naman po ang palit ng mga filters nya. pero never pa nareplace yung mga belts nya (except for the timing belt). i don't know if it's my driving, pero pansin ko na parang malakas na ata sya magconsume ng krudo.
and is it possible to install an intercooler sa adventure, or delikado po sya kung gagawin yun?? if ever na magpapacalibrate po ako, sa shop po ninyo sana ako pupunta. mukhang forte nyo na po mga diesel engines eh, so sa inyo po ako magpapachekup. san po ang location nyo?? thanks po in advance...
- Sep 2006
- 1,335
May 2nd, 2010 11:59 PM #950good day po.. newbie here.. pasensya na po bout sa mga common sense na questions ko, pero curious lang po ako kung kelangan ko na po ba icalibrate yung 4d56 engine sa adventure, since it's already have a 105k mileage. 7 years na din po sa min ung sasakyan, and every 5k kms eh change oil sya. every 10k kms naman po ang palit ng mga filters nya. Hindi kelangan icalibrate kung ok ang andar.
pero never pa nareplace yung mga belts nya (except for the timing belt). Good. Check/replace vee belts and coolant hoses as per owners manual recommendation.
i don't know if it's my driving, pero pansin ko na parang malakas na ata sya magconsume ng krudo. Siguraduhin mo muna.
and is it possible to install an intercooler sa adventure, or delikado po sya kung gagawin yun?? Wala yata turbo ang Adventure. Hindi makakatulong ang intercooler kung walang turbo.
if ever na magpapacalibrate po ako, sa shop po ninyo sana ako pupunta. mukhang forte nyo na po mga diesel engines eh, so sa inyo po ako magpapachekup. san po ang location nyo?? thanks po in advance... PM kita.
Tesla Philippines
