Results 221 to 230 of 361
- Sep 2008
- 11
September 25th, 2008 02:29 PM #221Sir, I have a 2006 Civic. Ano kelangan ko to upgrade to HID ng hndi makakabulabog sa mga makakasalubong? hehe kasi may binebenta sakin na Bosch HID lamps eh. kukunin ko na sana, buti na lang nabasa ko tong thread na toh. I ust wanna double check muna para sure na walang magagalit sakin sa daan. hehe Thanks.
September 25th, 2008 02:44 PM #222
kita mo hinabol pa kita dito sa other thread
check mo muna kung same type ang HID na binebenta sa yo para di sayang pera. iba iba kasi type ng sockets niyan. don't worry pwede i HID FD mo. see my post on your thread.
good luck...
September 25th, 2008 11:12 PM #223
September 29th, 2008 02:08 AM #225
This is a good set. Seems the lens is thicker than the ones normally seen on Delicas.
This is good for fogs if the intention is to reduce glare. There are plenty of vehicles today (incuding the new Mitsu Lancer) that are using orbital reflector fog lights to eliminate the glare, but it's never enough once you mount HID's on them. I've seen a lot of M3's, Focus, and Civics that instead of buying OEM fog light assemblies, they just buy a set of these projectors, fabricate a mount (which is simply just like replicating the bumper cover mounted on where your fog lights should be, and you may even use the cover included and mold it instead), bore a hole in the middle just to fit the projector. The fabricated assembly can then be held in its place by boring a small hole to where the provisions of the screw for the original fog lamps should be, and it should keep your fog lamps there.
Requires a lot of hard work, and I actually was aiming to do it for my Nissan, but work ate up all my free time for the last nth months. Dang...But... this CAN be done by a shop fabricating car chins and bodykits if you want it the easy way. May cost you though, but it's aesthetically nice and functionally superb compared to a plug and play HID installation on your fogs.
October 4th, 2008 10:24 PM #226
guys pwd ba aku mag karoon ng ganitong ilaw:
without buying a hid kit?
hnd kasi maganda ng ung throw ng light eh... same po ung beam at low..
ung foglight lng i retain ku when i encounter bad weather..
bulb lng sana..ung safe po..na hnd makakasira sa wirings..
pag install ku ng projector, nilagyan na mn nila ng relay..
guys, ito po ung car ku
November 8th, 2008 11:50 AM #227
Please rephrase your question and do not post in text-speak.
My assumption though is that you're asking if you want to have the same clarity as the reference image without buying an HID kit, my possible answers are:
A. If you already have an existing HID kit, you don't have to. Difference in light output between China HID and the astronomical kits offered in some other shops are too minimal to notice. Quality-wise of course, some China kits are Class B, but it goes on bulb-build and longevity, but light output wise, not so much.
B. The clarity of the light really doesn't revolve much on what your HID kit is, but on what your PROJECTORS are. Normally those used from the Acura TSX and Ultimate types of projectors produce superb cut-offs and width (the bluish color you see in some HID shots you search on the net or if you backread here), but of course costs more than the ones used for the BMW X5.
So, if your bulbs still light up and you want the same clarity that you get in your reference image, then best suggestion would be to go to Xenon Bulbs and buy a new pair of projector type headlight assemblies for your car (which I know they have) OR create your own custom-fitted assembly or even better yet, just buy a stock headlight assembly for your car somewhere and retrofit it with projectors. Whether clear-type or non-clear type lenses, plenty of projectors are pretty much available at your arsenal to retrofit. You have to note though that if you won't go the easy way out (buying a projector type headlight assembly), lots of rewiring works will really have to be done, not to mention the time and effort to align those projectors. HTHLast edited by batang_raon14; November 8th, 2008 at 11:53 AM.
November 12th, 2008 09:41 PM #228
thanks for the reply..
btw ito ung ilaw ng headlight ku.. notice mu rin ung parang may blue sa edge..ewan bakit may ganun.. tska 100watts na po yan.. nung una 55watts..pero ganun pa din kalabasan ng ilaw eh.. tried splitfire headlight ung magnun arc (white) 4200k, hnd puti ung lumabas..stil the same pa rin....ganun pa din ang kalabasan eh.. hirap sa daan..
anu ma suggest mu bro?
November 12th, 2008 09:42 PM #229
November 12th, 2008 09:55 PM #230
btw heres my headlight assembly
http://lib.store.yahoo.net/lib/mytig...lights-big.jpg
Tesla Philippines
