Page 2 of 9 FirstFirst 123456 ... LastLast
Results 11 to 20 of 84
    Jun 2011
    Hindi daw smooth shifting ang AGS. Baka mas okay ang Swift GL CVT? Mahal nga lang. Okay ang Wigo G, at G4 GLS.
    Wigo G
    Parts and maintenance
    Ok dimensions sa city
    Flexible HB space
    AC
    LEDs
    More safety features
    Dashcam
    Cheaper
    G4 GLS
    bigger trunk and passenger space
    Longer wheelbase, better highway ride
    Halogens - rain visibility, cheap bulbs
    Simpler CVT maintenance - w/ dipstick/filler tube, filter strainer, separate paper filter access
    Global model - madami surplus parts
    Buy PH
    AC
    Since HB preference ko, leaning towards sa Wigo. Or bare bones Mirage HB GLX (no ABS!). Hehe.
    doc, we're Toyota loyalists, aren't we?
    Wigo por supuesto
    somos mercenarios, probablemente.
    we go where the overall pay is better.
    so far, toyota seems to be the better employer, but we should not be deaf and blind to reasonable offers.
    so far, it's wigo...
    i wonder,
    may we now choose our ending digit on the plate number?
    Jul 2013
    I've never been a fan of the Mirage even since I rented one.
    New Wigo uses DNGA-B platform that's also used by the Raize, Avanza/Veloz, Yaris Cross and 4th Gen Vios.
    2024 Honda Brio vs Toyota Wigo: Big Test of small hatchbacks | Top Gear Philippines
    Nope, Wigo uses the DNGA-A not the B.
    Feb 2014
    weird yung d-cvt, physical gear is the top gear. while corolla's direct shift physical gear is at bottom where it should be that's why there's that acceleration weirdness towards 100kph with the wigo
    Nov 2017
    Quote Originally Posted by Vodka View Post
    It seems there is something wrong with the test vehicle(limp mode? Calibration for the PH market?) the Physical gear seems to set ~2000rpm at 100kph so they are still using the CVT albeit not being given shortest available ratio.
    https://www.youtube.com/watch?v=gLfFnnoZhUE&t=1014s
    After reading the press releases, I think both implementations make sense, just a matter of whether the car is being tuned for low or high speed efficiency.
    Either side is where you have a big differential in pulleys: big input to small output in "low gear" mode, or small input to big output in "high gear" mode meaning a lot of torque division or multiplication which can cause the CVT to slip more.
    So the corolla implementation is optimized for stop and go traffic, the wigo version is for highway cruising.
    I suppose a more ideal implementation optimized for both scenarios will have a two-speed transmission with the missing in-between gears filled in by the CVT.
    Nov 2017
    Quote Originally Posted by LOLZ View Post
    Edit: It seems like the CVT and the Physical Gear(when engaged) feeds a planetary gear set which makes it behave sort of like the Prius' Ecvt except a CVT transmission is doing the job of MG1 in controlling the gear ratio. The "Short shift" is more likely the vehicle protecting the CVT part of the transmission.
    Jan 2009
    This.
    A low-gear direct drive for stop-and-go, and a direct drive for the top/OD gear. That should make for a more reliable CVT, IMO.
    interesting.
    i guess i'll have to think what type of driving i'll be doing...
wigo versus g4
