Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 47
    Aug 2004
    #31
    Peak hp, peak torque... meaningless without a curve. Have a curve? Meaningless without the gearing. The gearing and power curve? Meaningless without considering the weight and aerodynamics of the car.
    Actual 0-100 km/h times? They'll tell you all you need to know.
    May 2010
    #32
    Bless us with your infos, Niky
    Posted via Tsikot Mobile App
    #33
    Irrespective of the drivers age, mabilis na ang 170 kph. Especially that the speed limit is at 100 kph. They are SUVs not Formula 1 car, they use public roads not race track. The time difference between a TCI SUV (MS, Eve, Alt, Fort etc) and a VGT/VNT/V** SUV reaching 170 kph is not that significant, they will still see each other at the toll gate, in the next traffic jam, in the next stop light or in the next speeding check point. If anything bad happened at 170 kph, they may again see each other at the same hospital and share the same emergency ward.
    We are not talking about public roads or speed limits. Read the title of the thread again, it is asking about SUVs. Wala naman tayo sa goon squad eh so what is your point? You are preaching in the wrong forum. Pinaguusapan what qualifies as an SUV and what is not.
    Time difference daw is not significant hahaha! You don't know the difference because you don't know.
    Apr 2008
    #34
    To get back to the topic, I do wonder. After looking at various Speedlab dyno sheets, I find that the Fortuner/Hilux 3.0 and the Montero/Strada 3.2 give only around 120whp. And then I see that the non VGT 2.5 Strada/Montero's also hit 120whp and a Strada GLS Sport V hit 170whp. I've driven the VGT Strada, and I know for a fact that it has difficulty going past 185km/h. What gives?
    Sent from my GT-I9100 using Tapatalk 2
    Jul 2012
    #35
    ^ Maybe the gearing comes into play.
    OT: I only need 2 things from an SUV:
    1. Head snapping torque.
    2. Space
    Anything else would be a plus in an SUV (comfort, handling, etc). But that's just me.
    #36
    Pinaguusapan what qualifies as an SUV and what is not..
    Topic:
    "SUV real world dyno outputs " <> "Pinaguusapan what qualifies as an SUV and what is not"
    Are they the same?? So who went out of topic first?
    #37
    Basahin mo from page 1 para malaman mo bakit napunta sa time from 0-100 kph to peak hp and torque and gearing, etc etc. All those are related to what the ts asked. Hirap kasi bigla na lang magpopost di naman nagbasa.
    #38
    Quote Originally Posted by GTi View Post
    Pick up kasi. Same as with my bt50, 200 hp and 470N-m torque pero i doubt if it will go past 185kph (speedometer is only up to 200 kph). It is designed to carry loads and pull trailers, not for top speed. Kaya yung upcoming 2014/2015 ford everest if it has the same gear box as the ranger/bt50 e it will not be worth it, especially if it also has the same quirks (wide turning radius, hard steering).
    #39
    Not really the gearing - whether I use 4th, 5th, or 6th gear, my Ranger has difficulty past 170 kph. 175 kph was my highest on a straight road. 180 with a slight incline. I doubt that after chipping it, I'll exceed 180.
    It's more of the aerodynamics - the Ranger has a drag coefficient of 0.40. The BT-50 shouldn't be far off. That's pretty low for a pick-up but still much higher than a car or even a CUV.
    More important than top speed though for me is responsiveness and acceleration from 60-120 because that's the average speed on our Nat'l Highways. Sa SLEX/NLEX/SCTEX lang ako nakakabyahe ng lagpas 140 kph effortlessly.
    #40
    WHP is peak power - still doesn't translate to how well the power is delivered. End result that you're looking for is still acceleration and sometimes, top speed.
    From experience though, I had a stoplight duel (that lasted 60 km) with a Strada GLX-V - it should smoke my Ranger 2.2 on the straights but it was dead even, whether it was from 0-160 or upon coming out of a corner or an overtake (approx 60-140).
    I used to feel bad about having "only" 148 hp but that 30 hp gap with the VGT Strada wasn't noticeable at all in real-world conditions.
