Page 92 of 307 FirstFirst ... 4282888990919293949596102142192 ... LastLast
Results 911 to 920 of 3070
    May 2009
    #911
    thanks ken...try ko maginquire kay jeff tan tomorrow morning.
    Nov 2007
    #912
    Quote Originally Posted by brod78 View Post
    Yan number nya try m text kng gising yan reply yan sipag sumagot sa text un haha
    May 2009
    #913
    ^^ hahaha actually inadd ko siya sa fb...at sinagot niya agad ako...2k for the two front doors...umm acoustipad daw gamit nila...
    Nov 2007
    #914
    Yup acoustipad butyl yan ginamit nya sa vios ko malinis gawa saka bantay Jeff tao nya mabuti .... ano gamit ni mickey ?
    Aug 2010
    #915
    Mickey's 4.8k quote is probably of StandartPlast Silver (StP - Home) which is an internationally known sound damping and deadening company founded in Russia.
    Brand name power lang yan. For a more accurate quote, it's best to ask how much do they sell their sheets. That way, alam mo yun price difference of the material (sheets) and labor and this could give you a better negotiating leverage.
    I don't usually discriminate on deadening. Habol mo naman dyan is mass -- the brand name? Not to much unless you're willing to spend extra. I do appreciate my StP's easy-installation process though and they use higher grade butyl (yep, meron din yan quality grades) for their products so if you're competing, these are usually justifiable expenses. If not, stick with the OEM mass market butyl ones.
    May 2011
    #916
    Quote Originally Posted by kenzie View Post
    akala ko asphalt tong acoustipad, parang nabangit na to before? balak ko din sana kasi before palagay e. pero nung sinabi na asphalt daw, nagback out ako.
    Apr 2008
    #917
    Mga Sir,
    How do i get intouch with Jeff Tan and saan ang shop nya?
    Thanks
    May 2009
    #918
    Quote Originally Posted by Rakenrol101 View Post
    Mga Sir,
    Thanks
    Araneta Car Accessories along araneta ave...malapit lang sa SM Centerpoint..
    add mo siya sa fb dun ka magtanong at mabilis naman siyang sumagot :-)
    Feb 2014
    #919
    Hi sirs,
    ask lang po ako about my planned set up newbie pa lang po ako so not really sure if good enough na po tong mga planned specs ko.
    I've got a 2014 avanza 1.3j, I'm planning to upgrade the speakers currently it has only front stock.
    Front and Back speakers would be 2way coaxials contemplating on pioneer,sony,jbl brands. these will be hooked up to my head unit
    I will stick with my HU as it already has usb and aux and preouts at the back. Based on specsheet it has 18w rms.
    For subwoofer im contemplating on
    1 Kicker comp 12" then house it in a 2.27 cu ft ported box based n kicker comp manual.
    -or-
    1 jbl gt5-1204br loaded enclosure.
    amp for subs would be sound magus dk600.
    Im willing to shell out around 20kish for the set up. I only want a decent sound system with a good bump in the bass.
    questions...
    1. will the hu be enough to power 4 coaxials? im seeing 40-50watts rms for each speaker based on the brands mentioned above
    2. is sound magus dk600 a good amp for my kicker or jbl?
    3. which of the two is better kicker or the jbl?
    by the way i'm from cebu and we don't have much shops to go to with car audio. if you guys have other suggestions i will have to check for availability.
    Dec 2007
    #920
    *sleep,
    1. Yes it will be enough but chances are the loud volume of the subs might over power the sound from the coaxials.
    2. Yes
    3. The JBL subs.
    I suggest get a 4 channel amp. to power 1 set of either coaxials or components for the front and a sub on the rear. No need to add speakers on the rear.
audio set-up for beginners [continued]
