Page 83 of 307 FirstFirst ... 337379808182838485868793133183 ... LastLast
Results 821 to 830 of 3070
    Jun 2011
    #821
    Quote Originally Posted by mikedp5 View Post
    sir jhnkvn, bout sa seps sir? nagtanong tanong kasi ako ng seps around 4k-5k, someone quoted me for JBL 609c for about 4.8k. Tinignan ko online sa amazon, it was priced for $230++. Twice ng price dito. Legit kaya tong 609c na binibigay sakin? Or too good to be true?
    Ganyan po ang binigay na price sa akin sa PERFECT CIRCLE * BANAWE. PERFECT CIRCLE po ang distributor ng JBL products for cars.
    Jun 2011
    #822
    Quote Originally Posted by jhnkvn View Post
    They simply indicate flexibility. Sa mga mga ganito, more = better.
    Okay, for a more in-depth post, most good head units come with 3 pre-out RCAs that are divided into three sections: Front (Left and Right), Rear (Left and Right), and Subwoofer. The more budget ones from Pioneer and equivalent comes with 1-2 pre-outs which usually is either Front (Left and Right) only or Front + Rear.
    It is hard to generalize that pre-outs limits the number of amplifiers you can use since you can have external processors, Y-connectors, etc. to further "expand" your external amplifiers.
    Oh i see po sir. Others will have a separate amplifier for each and every RCA-OUT. Tama ba sir?
    Nov 2013
    #823
    good PM mga sirs!
    question din related sa JBL.
    i would like to have an SQ setup.
    however, unti-untiin ko lang muna etong project ko due to funds
    for the initial setup, ayos lang ba na unahin ang seps, 6x9, at HU?
    i am thinking JBL seps and 6x9, tapos pioneer HU.
    next na yung amplifiers and subs...
    hindi ko pa naman siya papa-bayohin nang todo. sufficient na sa akin for the meantime na clear yung sound inside the car.
    pa-feedback naman tungkol dito.
    TIA!
    May 2013
    #824
    Quote Originally Posted by X-salta View Post
    aahh. nice. may number po ba sila? Legit naman po siguro un GTO 609c nila? Kahit it's way way cheaper than states?
    Jun 2011
    #825
    Eto po sir
    Perfect Circle Industrial Supply Corp
    90 Banawe Street, Quezon City
    Phone: +63 26329612
    Fax: +63 26329727
    May 2013
    #826
    Eto po sir
    Phone: +63 26329612
    Fax: +63 26329727
    nagiinstall din ba sila? un po ba kinuha niyo na seps? GTO609c? maganda naman po ba? may idea kayo ano next higher priced model and next lower priced model?
    EDIT: oh and also, comparable po ba saan un sound quality ng gto609c? compared po sa mga dls, a/d/s, morel?
    Jun 2011
    #827
    Yes, nag iinstall po sila
    Kukuha pa lang po ako nito sir, ipon mode pa together with the Head Unit
    I think so kasi nasa middle range siya
    Nasa 8K++ pesos na ang susunod na price dito. High end na kasi.
    Marami din kasing model ang Morel and the like. Depende sa budget, parang may stages 1, 2, 3
    May 2013
    #828
    Ask ko lang mga audio gurus, ano ba maganda next na upgrade ko. Upgraded na ko ng HU to pioneer, then mag amp ako ng powerbass 4channel asa600.4x then upgrade ko din un Kinetic KD6 ko to JBL GTO609c. Sub ko is JBL na entry, un gt5-s12 ata un. ano maganda next na upgrade? upgrade ko na ba un coaxials sa likod? or get mono amp for sub? may igaganda pa ba un sub ko if mono ang amp niya vs bridged from the ASA600?
    Apr 2008
    #829
    Hi Sirs,
    Anyone here has tried or tested Kinetic seps and coaxial?
    Upgrading my stock set up (Suzuki Swift 08)
    Head unit panel customized (Mahal kasi yung orig panel) - 3K
    Pioneer 2550UI - 3.5k
    Kinetic seps 6.5 - 3.5k
    Kinetic coaxial 6.5 - 1.8K
    Any comments or suggestions mga sir?
    Aug 2010
    #830
    The best way is to buy from authorized resellers. Contact Perfect Circle Industrial Supply Corp (Phone: +63 26329612) and ask.
audio set-up for beginners [continued]
