Page 183 of 307 FirstFirst ... 83133173179180181182183184185186187193233283 ... LastLast
Results 1,821 to 1,830 of 3070
    #1821
    Thanks bro. lubusin ko na ha since i got your attention, how's the quality (durability) of the phoenix brand?
    Di naman basta-basta nasisira yung amps basta properly installed. Kung di mo naman i-max-out yung gains ng output, no chances of it burning out. Also, branded amps have their quality checks so it will not be as unreliable as those unbranded V12s common in the market.
    Saan mo ba gagamitin yung class D amp? For loud purposes ba? Mas malakas kasi output ng class D kasi less yung power loss. If you're looking for just in-car listening with focus on sound quality, you can always count on class A/B amps, specially from noted manufacturers like DLS, Focal, Rockford Fosgate, Audison, etc. A friend from NB before created an award-winning SQ setup using class A/B amps (Genesis) for his seps and used a class D mono amp (Alpine PDX) for his sub.
    Apr 2012
    #1822
    Whats the cheapest class d amp with about 70w/ch 4 channel? And 200watts mono narin for the sub? Thanks
    cheapest 5ch i know is yung JBL GTO series 5355 55Wx4 + 225x1
    check mo din bro yung DLS Reference CC-4 70Wx4 saka DLS CC-2 170x2. maliliit lang na amp yan, nakita ko sa friend ko sa ilalim ng upuan. he's running full active with it and maganda din tumunog...
    kay bro jonz sa simplesounds, audison SR4+SR1D at SR5 usually mga gamit na amps sa installations niya...
    i'm using PG SD800.5 sa kotse ko, may konting noise sabi ni bro jonz pero di naman dinig sa untrained ear ko
    #1823
    What should I expect in replacing stock speakers on a car?
    Sira na yung isa, will need to replace the front pair with the most basic ones I can find.
    a) How much should I prepare?
    b) Will stock wiring handle this?
    c) Any splicing involved, or are there plug and play sockets?
    #1824
    ^^^ Class A/B yung JBL GTO5355 at DLS CC amps.
    #1825
    These are the options i can afford (if available)
    Sound Magus H500 12,500.00
    JBL GT0 Series- 5355 /5Ch.Amplifier 12,185.00
    Lightning Audio LA-51000 13,400.00
    Phoenix Gold SD-Series Amplifier SD800.5 16,500.00
    Precision Power Sedona Class Amplifier S580.5 11,900.00
    i would really love to get the all class D channels, as i want effeciency more than anything else.
    they say class d is on the harsh side; but ive listened to class d amps in home theater setup, sounds fine for me.
    eto kaya good deal na ba for 5.5k?
    https://www.*******/item/q-car-amplif...126#037f9d6126
    #1826
    siguro dahil mas poise lang class A/B pagdating sa distortion, and mas evident naman sa class D?
    i dont think magkaroon ng noise yung amp kung OK naman ang speaker/amp matching tapos di i-overdrive like what Egan101 said.
    iirc i met with jonz already bro, marikina eb; nahihiya lang ako magtanong din dun kasi hi-end mga setup nila
    #1827
    btw here's what i have right now
    "Alpine V12 4 channel"*fake obviously lol.. bridge for subwoofer duties (with broken power ic)
    JL Audio 12W3v3 (sub)
    JBL GT5-652 (rear)
    cant see the front speakers yet, will update soon
    #1828
    Decided not to use the 12" JLW3 sub
    Ok lang ba or meron ba 6" woofer lang, para ilagay ko sa rear?
    Apr 2012
    #1829
    i see, class D nga pala hinahanap ni sir ninja na amp
    sir ninja, are you letting go of your jl w3? if so, pm mo ako baka pwede ko ilipat sa likod ng monty ko...
    meron naman mga 6" na woofer, check mo sa website ng mickey's. yung mga nagkakabit ng 6" instead na sa rear, sa kickpanel sa front nila inilalagay..
    #1830
    Keep the subwoofer and forget about the rear speakers. You can attain a decent sounding audio setup with a good set of seps and a subwoofer.
audio set-up for beginners [continued]
