Page 295 of 307 FirstFirst ... 195245285291292293294295296297298299305 ... LastLast
Results 2,941 to 2,950 of 3070
    #2941
    Quote Originally Posted by Sleepcare View Post
    CTK brand ng sound deadening material. 240 not bad na. Sa direct ka ata nakabili..
    not sure bro pero close to 5k nagastos ko. i think reseller nabilhan ko 3 years ago bro kaya mura kasi sa volume at free delivery pa.
    flooring, double walled doors (all 4 doors), at trunk lang di ko nalagyan hehehe
    btw CTK is better?
    Aug 2009
    #2942
    btw CTK is better?
    Wow included pa flooring sa 5k sobra sulit na! Madali lang ba lagyan acoustipad yung flooring?
    Sobrang takimik nung kotse niyan lalo na kapag wala kalampag. Hehehe
    Sa next project pwede ka na din roofing para hindi mo na maririnig yung ulan sa bubong
    CTK is better kasi lighter vs acoustipad. Also yung materials used is different.
    Pero personally i'll stick with acoustipad kung flooring lang. Then sa door, outer is CTK then acoustipad yung pinaka-door wall mismo.
    #2943
    parang di daw vios bro yun NVH, pero im sure mas maganda parin yun insulation ng camry or same level
    btw bro sa 5k pala dapat kasama na trunk, di ko pinatuloy hehehe
    binigay ko sa installer yun natira
    Aug 2009
    #2944
    Mag lessen daw kasi road noise kapag nilagyan deadening sa flooring.
    Insulation actually pwede din in between ng flooring tska deadening sheet. Kakapal lang kapag inapakan mo
    Pero 5k sa flooring and double wall sulit na din sa totoo lang. Nakakangawit kasi yung parang roller na ginagamit. hehe
    #2945
    ^heat gun ginamit sakin bro. baka palgyan ko ulit next car ko, pero ang laki din ng weight penalty eh
    Jan 2008
    #2946
    deadening na asphalt? tried that in my altis pero parang wala naman halos effect.. much better yung fiberfill plus rubber na insulation.
    Aug 2009
    #2947
    Ramdam ba sa hatak?
    Yes.. dapat ata kasama din yung near engine firewall para malaki yung effect.
    Sep 2011
    #2948
    Hello mga Masters,
    My ride is a Suzuki Vitara GLX 2018 model with deadening installed on four doors and has the following setup,
    HU: Stock Allwinner Brand with 10” screen (CPU:1.6GHz Arm Cortex A7, RAM:1GB, ROM:16GB, OS:Android 6.0.1)
    Front: JBL GTO 609C seps
    Rear: JBL GTO 629 coax
    Amp: Planet Audio Anarchy AC1600.4 (4-channel amp with total rated power of 800W *4ohms)
    Sub: Planet Audio PA8W (powered underseat subwoofer with rated power of 800W)
    LOC: DS18 V5HL (for the HU kasi walang RCA outputs)
    I’m not satisfied kasi on how the tuning was done after all the hardware was installed. Yong ginawa kasi ng installer yong tuning tenga lang kasi ginamit wala man lang maski a simple voltage measurements using a voltmeter to check on the input and output signal levels at different stages. In my novice opinion parang kulang or hindi tama yong pagkagawa sa installer and wanted to redone it properly in a meticulous manner in my own limited way at no additional cost for optimum SQ. Although newbie lang ako sa car audio, Im a willing learner and could learn fast basta pasensyoso lang yong mag guide sa akin. Can you guys help me with this, please? How do I start with the above given setup?
    Thanks in advance.
    Aug 2009
    #2949
    Quote Originally Posted by troscat View Post
    Hello mga Masters,
    Thanks in advance.
    Nothing wrong if tuning was done by ear to be honest. Almost all usually starts with the equipment then tune ulit by ear pero usually minor details nalang.
    No additional cost means bringing it back to the installer and telling him/her the problem. Wag ka muna papayag na pabilhin ka ng ibang items.
    2nd option is bringing it to another installer for checking. Pero usually eto at cost na kasi gagamitin mo oras niya.
    Where's your location?
    #2950
    ^Bang for the buck yung Morel Maximo Ultra
    *jut703
    Araneta Car Accessories has a 25k all Pioneer budget build, 40k Focal auditor build.
    For underseat sub, it will cost 10k for the unit. (I think that's already the installed price)
    If we'll use the package price, amplifying all the speakers and using the underseat sub will cost around 30k.
    Front doors - 2 way seperates
    Rear doors - coaxials
    *techglimpse
    Had 1 before. Good enough kung basic upgrade lang hanap. Maboses yung pioneer 2-way kaya ramdam na agad difference vs stock and lalo na deadened yung doors for the midbass.
    Spacer lang yan. No drilling needed.
    Mahal din pala? Akala ko kaya lang mahal yung Kicker setup sa CRV kasi galing Honda. Eh 40k din pala price sa labas so same lang.
audio set-up for beginners [continued]
