Results 181 to 190 of 287
October 27th, 2018 09:42 AM #181
- 53,883
October 27th, 2018 09:53 AM #182
- Nov 2009
- 3,503
October 27th, 2018 10:09 AM #183Clean with vinegar or dab of Turco, if still not clean use industrial grde hcl acid. The silting on the cover numbs the sensor w/c is just usually a thermistor wrapped in polymer.
- May 2011
- 481
October 27th, 2018 11:28 AM #184seems like everybody is helping you chase your tail.
check the voltage at the dlc3 terminal. see link:
Getting Started with OBD-II - learn.sparkfun.com
it is more than likely communication problem. please, give it a try and provide voltage readings after the test.
no offense to anybody trying to help.
- Jan 2010
- 283
October 27th, 2018 01:03 PM #185
October 27th, 2018 06:56 PM #187
- May 2011
- 481
October 27th, 2018 08:00 PM #188engine coolant temperature sensor (ECT) will have pink wire on terminal 1 and light blue on terminal 2
ALLDATA
on this one, the fan does not run when you unplug this sensor. this is, a negative temperature coefficient resistor or a thermistor (NTC resistor). unplugging it will simulate the coolant temperature is below freezing
this link has a very short shelf life. open link, print the information ASAP
October 28th, 2018 04:04 AM #189
October 28th, 2018 05:11 AM #190
new water pump, OK pa yun luma. pinapalitan ko narin since nabili ko na prior to going to exalta banawe.
wear and tear naman ito no? pwede reserve nalang yun luma?
Tesla Philippines
