Page 27 of 29 FirstFirst ... 1723242526272829 LastLast
Results 261 to 270 of 287
    #261
    ADR yung three letter word na radiator siguro. Evercool is good too. Used it on my 96 City before. Disadvantage is tanso siya so mas mabigat sa stock na plastic/aluminum.
    Same sentiments. Sa dami na ng brands ngayon mas gugustuhin ko pa na brand new. Siguro kapag sobrang nagtitipid tsaka lang tsaka ako magpaparepair.
    #262
    Evercool is local OEM for mitsu kaya may kamahalan. The taiwans are cheap and good quality, i just replaced one for hyundai and throw away the old nabulok dahil hindi nagpalit ng coolant.
    Kaya yun DIY minsna nagiging Destroy it Yourself..Hehe.
    Kaka kalikot yung pyesa na nabuksan at nagalaw dun nanganganak problema.
    Kaya minsan need talaga research gather experienced method to find the root cause than the elimination method of troubleshooting.
    Eto co-worker ko nag PMI DIY ng brake drum cleaning na hindi binacking ang adjuster, ayon pinwersa using eject slot na tornilyo kaya misaligned need nya palitan brake shoes.
    #263
    Naging Destroy it yourself. Hahaha
    Its all part of the learning process....
    #264
    ill checkout my work later, kung ok ba or hindi yun alum clips
    if ADR nga yun sa toyorama, ok na kaya yung ADR bro?
    sa weekend mag semi long drive ako, then check if may leak yun DIY ko. ngayon kasi naka distilled water muna, kaso di madetect sa distilled water dahil nag evaporate agad, nun pinalitan ko nalang ng coolant, tsaka ko nakita yun mga tulo from a very small leak.
    Jun 2005
    #265
    bro ok ba brand nikko? ano brands gamit nyo na replacement lang? orig is * 15-20k eh
    observe ko muna diy ko, if not palit nako bago hehehe
    Nikko is one of the go to brands for vios parts ng mga mechanics that specializes on the vios...
    Sent from my MI MAX 2 using Tapatalk
    #266
    Same level si ADR at Evercool. Parehong locally made. I suggest go for two rows para may extra cooling capacity ka. Naka dalawang track day din yun plus daily drive pa. Walang problemang binigay sakin.
    #267
    ^ i'm not sure but i think taiwanese made ang adr bro.
    i bought an evercool rad for my ek several years back to replace the original oem rad it came with and it performed very well. the price is worth the quality of the product.
    btw, iyong adr ba aluminum na? kasi iyong 2 row evercool na nabili ko dati gawa pa sa brass.
    #268
    thanks bro
    will call toyorama now and confirm if ADR nga [emoji4]
    #269
    thanks bro
    promax daw dating ADR and same packaging.
    #270
    I might be wrong about the origin of ADR. But im sure evercool is locally made.
Radiator / Overheating Problem
