Results 51 to 60 of 68
- Jun 2005
- 3,774
March 22nd, 2020 12:30 PM #51
- Feb 2008
- 898
September 29th, 2020 08:47 PM #52Mga bossing, yung Fortuner 2016 (Dsl 4x2 Automatic Trans) ko ay nakaabot na ng 40,000 km so kanina aside sa change oil, nag-pa drain din ako ng ATF para pailtan. However, yung na drain lang ay nasa 3 liters lang. Ang nasa Toyota Manual/Handbook yung ATF is nasa 9,5 liters. Dahil 3 liters lang na na-drain, 3 liters din ang napalit. Hindi kaya na sayang lang yung new 3 liters na ATF dahil yung karamihan sa natira ay lumang ATF na maitim?
- Jan 2008
- 4,726
September 29th, 2020 09:12 PM #53again, may tamang procedure sa pag drain ng ATF ng toyota transmission na walang dip stick.. watch you tube videos.. dapat nasa tamang temp yung transmission pag drain.
if i remember, same yung fill plug at drain plug nyan. may parang straw sa loob na mag dictate ng level ng ATF at the right temp. kaya yung nakuha na 3 liters ay malamang dahil mainit yung ATF at nag expand na sya..
September 29th, 2020 09:25 PM #54
September 29th, 2020 09:28 PM #55
9.5L might be the total amount of fluid in the whole tranny system. In most drain and refill method for AT trannies, the amount of fluid drained is just about a third of the while liquid content.
You will need a dialysis method to change the whole content of tranny fluid.
September 29th, 2020 09:38 PM #56
- 53,883
September 29th, 2020 09:47 PM #57there is this belief by some mekanikos,
that a hot fluid has more dissolved and suspended impurities and gunk in it, than not-hot fluids.
hence their preference of draining when hot.
it's the same belief when draining engine oil.
September 29th, 2020 09:55 PM #58
- Jan 2008
- 4,726
September 29th, 2020 10:04 PM #59
- Jan 2008
- 4,726
September 29th, 2020 10:06 PM #60
