Results 61 to 68 of 68
September 29th, 2020 10:14 PM #61
- Feb 2008
- 898
September 30th, 2020 08:00 AM #62Apparently, when the mechanic drained the ATF it was still hot kasi kasabay sya sa pag-drain ng engine oil (nag-pa change oil din ako). The ATF drained was around 3 liters so "marami" yung na drain na 3 liters? did I get you right? since 3 liters yung na-drain 3 liters din yung linagay pag-fill up. Tama ba yun?
Should I be worried about what was done to my tranny? Should I go to Toyota to check if nothing was done wrong or the ATF was still enough? This morning I checked if meron bang tulo pero wala na man....
September 30th, 2020 08:31 AM #63
Normal drain and refill will do if you are changing tranny fluid within short intervals like 40k km. If it is done over a long period, you can do the dialysis method. If you have no dialysis machine, you can do drain and refill in a multiple sessions until you have used up a total volume needed. On your case, maybe 3 drain and refill sessions.
- Jan 2008
- 4,726
September 30th, 2020 09:23 PM #64since ATF expands when hot, the 3 liters you got is expanded.. so when it cools, that 3 liters maybe 2.5 liters only (my assumption only.. not exact figure but we all know ATF expands when hot that is why we have "hot zone" and "cool zone" in the dip stick)
now since you put 3 liters of room temp ATF, when it gets hot, it will expand resulting to overfill of 500ml of ATF..
i believe, fortuner transmission (without dipstick) in the drain plug, there is a small plastic "straw" protruding in the oil pan that maintains the ATF level.. at the manufacturer specified temp, the ATF expansion will just be enough to level on that "straw".
- Feb 2008
- 898
October 1st, 2020 08:51 PM #65
January 4th, 2023 01:50 PM #66
Finally had an atf filter change kanina along w/ the usual atf change on my civic fd2. Mukhang ok pa naman and walang mga metal shavings na unusual according to the mechanic.
Ito Pala iyong in-line atf filter nya
Sent from my RMX3690 using Tsikot Forums mobile appLast edited by baludoy; January 4th, 2023 at 02:01 PM.
January 6th, 2023 03:59 AM #68
^ 152k ++ kms na din tinakbo niya bosing
Tesla Philippines
