Page 141 of 1548 FirstFirst ... 4191131137138139140141142143144145151191241 ... LastLast
Results 1,401 to 1,410 of 15472
    Aug 2008
    #1401
    Mga Kapatid, i'm here in Indonesia now and i saw a new model Innova, New head light, tail light and Front grille. also a new model Avanza with new head light, Tail light and Front Grille. iba na ung shape ng Head light ng both Innova and Avanza. i hope i can post pics soon. ang nakakatuwa d2, Daihatzu also has the same car like Avanza its branded as Daihatsu Xenia.
    Aug 2008
    #1402
    Bago din pala ang shape ng Hood ng New Model Innova d2 sa Indonesia.
    Heres their site, better than any blurred pic that i could take :D
    http://www.toyota.co.id/product/?pag...=Kijang+Innova
    Aug 2008
    #1403
    PT Toyota Astra Motor
    Feb 2011
    #1404
    Quote Originally Posted by SEALANDER View Post
    Pag naka handbrake ka step on the brake pedal first then shift to D then release the handbrake then the brake pedal. The reason why you should press the brake pedal before shifting to D is to prevent you from accidentaly stepping on the accelerator pedal while shifting gears to avoid rearending the vehicle in front of you. As you can see may jerking motion yan when you shift from N to D.
    Yung sa above ay para maavoid mabunggo ang harapan, how about yung nakakasira ng transmission? Kailangan pedal pa rin regardless nakahandbrake ka? Teka consult ko na nga din sa owner's manual. hehe.
    Apr 2005
    #1405
    Quote Originally Posted by ACidGaMbiT View Post
    Ang malakas makasira ng transmission ay pag naka stop ka sa traffic and you stay on D tapos naka apak sa preno. Pag stop mo shift to N then apply the handbrake. Yung iba kasi pag alis ng bahay hanggang destination puro D lang. Isa pa proper maintenance lang ng transmission oil will help in maintaning your transmission.
    Oct 2011
    #1406
    Quote Originally Posted by D4D AT808 View Post
    Is that the new Kijiang?
    Aug 2008
    #1407
    Yes, And they also have a New Avanza. same looks with Diahatsu Xenia :D
    Aug 2008
    #1408
    As a rule when on full stop shift to "N"eutral and if shifting to "D"rive or "R"everse depress the brake pedal first. the Hand break usually is used when you have to engage your brakes for extended time like when you park your car or if the traffic stop is very long and your leg is already strained.
    Oct 2011
    #1409
    I was driving home earlier this evening then suddenly it rained. I switch-on the wiper and notice that a part of the windshield is not cleaned by the wiper. So basically, that part of the windshield is blurry and with rain droplets which is unfortunately to my eye level. When i arrived home, I check the wiper blade and push it hard to the windshield para lumapat ung wiper blade sa windshield. I switch it on again but same thing happened. May part na hindi nalilinis ng wiper blade. It shape like an arc ung blurry part na un kainis. What is the best thing to do?
    Feb 2011
    #1410
    kung ganyan na nakalapat naman eh ganun pa din, replace wiper blades na lang brader. baka kasi may part na sa wiper mo ngayon na lumutong due to heat of the sun na laging na eencounter ng blades pag nakadikit sa salamin. :D
Toyota Innova Owners & Discussions [continued 3]
