Results 3,731 to 3,740 of 5533
November 6th, 2015 01:48 PM #3731
So walang function to unlock the doors when you remove the key from the ignition?
November 6th, 2015 02:13 PM #3732
November 6th, 2015 02:23 PM #3733
Ano ang gusto mong iactivate?
Yung shift position linked door lock and unlock?
Shift position linked door lock (for G-A/T only):
1. All doors should be closed.
2. Switch the ignition to "ON". Keep the shifter in "P"
3. Within 20 sec of step 2, press and hold the lock button for at least 5 sec.
4. Release lock button. There should be a cycling of the lock unlock. This means that the programming is successful.
Shift position linked door unlock (for G-A/T only):
3. Within 20 sec of step 2, press and hold the unlock button for at least 5 sec.
To cancel the function, perform the same steps.
November 6th, 2015 02:28 PM #3734
Wala Jut, but you can activate #4 which unlocks all the doors when you pull the driver side inside door opener within 30 seconds of turning off the engine. If #4 isn't activated, only the driver door unlocks.
I didn't activate this on mine na because I set it to unlock when I shift to "P" which we normally do before turning off the engine.
Sa techstream, on off lang itong mga features na ito. Wala ng complicated steps.
November 6th, 2015 03:56 PM #3735
November 6th, 2015 04:03 PM #3736
November 6th, 2015 04:20 PM #3737
Are you trying to disable/enable the speed sensing lock? "N" and lock for 5 seconds is for the speed sensing lock. Is the key turned to "ON" too?
Just checking lang ha. But that's strange.
I wasn't able to do this manually too the first few times. When I got it right, it becomes easy na.
November 6th, 2015 04:27 PM #3738
November 6th, 2015 04:38 PM #3739
November 6th, 2015 05:14 PM #3740
Tesla Philippines
